Technical SOS...55 FORD rear diff breakdown
Discussion in 'Traditional Hot Rods' started by Boxcar's 1928, Mar 10, 2021.
  1. Boxcar's 1928
    Boxcar's 1928
    Solicitation of pointers on how to get this center cluster out. Had a freebe 55 Axle lying around and thought I'd give it a look over. Don't really know what I'm doing. Haven't gotten rough with it so far....thought I'd pause to ask a question. While it may be an unpopular choice....I suspect that as long as it meets my width requirements....it could more than handle the 8ba in front. The cover only comes close to removal then stops. I suspect maybe the gear is being held or ??, Or may need to push on thru (give it some more grunt???)
  2. 51504bat
    51504bat
    You did pull the axles. right?
  3. Ebbsspeed
    Ebbsspeed
    Axles out?
    Edit: @51504bat beat me to it.
    ottoman, Budget36 and Boxcar's 1928 like this.
  4. Boxcar's 1928
    Boxcar's 1928
    Thanks.....will report back
    Budget36 likes this.
  5. 54vicky
    54vicky
    me thinks he did not remove axles;)
  6. Me thinks the same, but if the axles have been pulled, a little more grunt. Ford used that axle thru 56. Will hold up behind a flatty, but hard to find parts for.
  7. Budget36
    Budget36
    Ever had an “oops” moment?
  8. Zax
    Zax
    A little trick for pulling the axles is to turn the drum around and thread the lugnuts with the flat side towards the drum on until they are flush with the studs. Then use the drum like a slide hammer.
    Hnstray, loudbang, mgtstumpy and 2 others like this.
  9. 38Chevy454
    38Chevy454
    Another low budget axle removal trick is put a reasonably big chain several feet on a lug. Then snap the chain. That reaction at the lug will help pull the axle loose.
    Sent from my SM-A102U using The H.A.M.B. mobile app
  10. Boxcar's 1928
    Boxcar's 1928
    Yes indeed it was an Oops moment but got to learn on it!! In the end I found damage to the ring gear...I may have caused it but I'm not sure. At this point....current 3rd member issues, a rebuild, no drums, no brakes.....I believe it's ready for the s****per. Thanks to all for the tips....
  11. squirrel
    the gouges on the big round part of the case are probably from the pinion nut getting loose, so the pinion gear moved back...which is also probably related to chipping off the ends of some ring gear teeth.
    Yeah, it's gonna need some work, and there's probably a better one to start with out there, somewhere.
    Boxcar's 1928 likes this.
  12. jimmy six
    jimmy six
    First thing is 55's were noisey, second was they were noisey. They were the same/similar from 49-56. Lots have been taken out. I'd did and sold it complete for $100. A lot of 55-56's are upgrading now as we are seeing more of them... Keep checking Craig's list. Their highest ring and pinion was 3.22. Something to also think about.
  13. 51504bat
    51504bat
    An 8 inch out of a Maverick will swap in with only changing the spring pads. One from a '65/66 Mustang or Falcon will work as well but IIRC its just a tad bit wider WMS to WMS.
    winduptoy and Boxcar's 1928 like this.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    Hnstray and Boxcar's 1928 like this.
  15. 51504bat
    51504bat
    The later Ranger 8.8's were wider, 58" IIRC.
  16. okiedokie
    okiedokie
    from Ok
    Gee, the 3.31 in my 55 is very quiet.
  17. jimmy six
    jimmy six
    Glad to hear it. We bought a new 55 and whined the 9 years we had it. My dad knew if many that did. Our 56 was quiet. 3.22 or 3.21 were available in 56. I was just stating that the highest available from 49 thru 56 was the 3.20’s
