Technical Source for additional dies for JD2 bead roller?
Discussion in 'The Hokey Ass Message Board' started by TigerFan, Jul 5, 2016.
  1. TigerFan
    TigerFan
    from Athens, GA
    I got a deal on a great JD2 bead roller at the swap meet this weekend. However, it only came with one die. JD2 out of Ocala, FL) doesn't make bead rollers anymore, and I need more die options. Does anyone know if any other manufacturer's dies will work?
    I am new to bead rollers, but understand that the bore diameter is the key measurements to see if a Covell or Mittler Brothers die, for example, will work. But it looks like there's is a key on the shaft, fitting into the back face of the die (facing the frame), and I don't know if other manufacturers have this.
    Any ideas? Thanks in advance for the help.
  2. buffaloracer
    buffaloracer
    from kansas
    A good home machinist can make you about anything you need.
    Find a good old man and don't rush him.
    Pete
  3. Marty Strode
    Marty Strode
  4. TigerFan
    TigerFan
    from Athens, GA
    Thanks. That's really helpful.
    Does anyone have experience with replacing a JP2 die specifically?
  5. brady1929
    brady1929
    Are you sure it's not JD2?
  6. TigerFan
    TigerFan
    from Athens, GA
    Sorry, my mistake! It is JD2.
