Projects Source for replacement tube seats - brake caliper
Discussion in 'The Hokey Ass Message Board' started by ppsi1216, Mar 14, 2020.
  1. ppsi1216
    ppsi1216
    Anyone know a source for replacement br*** tube seats for brake calipers? I have a couple of Kelsay Hayes calipers with damaged seats that I'd like to replace.
    Thanks.
    Sent from my Pixel 2 using Tapatalk
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Perhaps drill out the seat and tap for pipe thread , then use an appropriate adaptor...
    ppsi1216 and Hnstray like this.
  3. ppsi1216
    ppsi1216
    NPT fittings are not suited for the high pressures of a brake system. Doesn't mean it wouldn't work though [emoji16]
  4. 57 Fargo
    57 Fargo
    You better tell every hydraulic brake light switch this important piece of information....plenty of NPT fittings in hydraulic systems running higher pressure than our brake systems.
  5. 270dodge
    270dodge
    from Ohio
    I recently sourced a high pressure gauge and I remember finding a 15,000 psi model with 1/4 NPT connection.
    Blue One likes this.
  6. Yes they are,
    Been thru this wives tale **** a few times.
  7. DDDenny
    All three of my cars' brake systems have NPT fittings, many modern aftermarket mfgs use them.
  8. Those calipers are shot, the cost of properly disposing of them is outrageous. I'll send you my address and properly dispose of them for you. LOL
    You are looking for a replacement fitting or a replacement seat that is inverted flare? Fittings can be had at any hydraulic repair shop a seat is probably another problem all together they were probably not a removable seat.
  9. ppsi1216
    ppsi1216
    From what I've read these br*** "tube seats" are replaceable in the kelsey Hayes 4 piston calipers. Lots of mustangs used them, again, from what I've read.
    I looked closer at mine and I think they will be fine. I tighten a new double flare line and nut into each one and they all seem to seat well.
    As for the NPT fittings not being up for the pressure I agree that NPT will take plenty. I was quoting from online sources. More than a few said not for hydraulic systems. I don't believe it either hence the smile emoji. Just my seat of the pants feeling is that I like a quality double flare over an NPT connection fwiw.
  10. DDDenny
    Not to derail your thread with continued discussion about NPT but................
    You do know (maybe not) that many aftermarket brake components are tapped NPT and can accept any number of seating arrangements whether AN, SAE, etc. (there are others).
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    Where in the hell do people come up with this ****. ??
  12. someplace between Saturn and Neptune
    BD0C2FD3-53C0-4299-8771-F8C6BAA11184.jpeg 7BF66154-A28A-44FB-977D-D8710D2F71A4.jpeg 26C58600-69BB-481D-BD0D-09908C150435.jpeg 8BC5147C-24A8-4B40-984E-36608AA60D66.jpeg C4E1705F-82C4-443B-9CC4-42ED67270D9B.jpeg
    Black pipe, which may have NPT on it isn’t suitable but that’s the water/NG pipe not the NPT
    kidcampbell71 likes this.
  13. ppsi1216
    ppsi1216
    OK. Thanks.
    My fault. I guess I was looking at some online information and overlooked the "black pipe" caveat.
    Yes thank.
    So sorry if I offended any npt fans. Who knew!
  14. hemihotrod66
    hemihotrod66
    If you can remove them you might try getting them from Dorman Products...they make lots of offbeat stuff in those Help Packages...
    ppsi1216 likes this.
  15. Marcosmadness
    Marcosmadness
    The people to ask are those that are in the business of rebuilding brake components.
    Apple Hydraulics, for example. www.applehydraulics.com They could tell you if the seats are even available. They might not want to share the source, of course.
  16. Anyone who’s ever seen some aftermarket parts I guess
    57 Fargo likes this.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Or worked on an automotive brake system !!
  18. ppsi1216
    ppsi1216
    OK well I guess it had to go here. Folks with very big, yet extremely fragile egos tend to make such posts as these. I've was young, ****y and such eearly in life and I'm hoping you two are not older than I was when I realized I didn't know everything. I'll happily put my experience, skill and know how about restoring automobiles against either one of you posers. What do you say? You two wish to go head to head with me? You want to show everyone how much better you are? Take the challenge please. You name it and I'll consider it. Show me what you got that permits you to mock other people. You two must be the best of the best huh?
  19. 61cad
    61cad
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Over react much ? , bit thin skinned ? Did people not tell you that just because its on the internet doesn't make it true .?....here or anywhere ....
  21. ppsi1216
    ppsi1216
    Um, not really sure what you are saying so no comment I guess.
  22. seb fontana
    seb fontana
    from ct
    I got some SSBC alum calipers [$$] that are 1/8th pipe with 90° adapter to 37°AN brake line, with some loc ***e to keep from getting loose. Wonderful. An "o" ring adappter would be best.. But what do I know.
    31Vicky with a hemi likes this.
  23. Looks like somebody got **** hurt here
    and just from the truth.
    Wouldn’t it be nice if nobody ever “LEARNED” ******** so then of course nobody would ever get mad at the truth. The truth is GOOD but man it’s touchy
    54vicky likes this.
