Sourcing some material
Discussion in 'The Hokey Ass Message Board' started by Willy301, Dec 9, 2012.
  1. Willy301
    Willy301
    Guys, been building a "one off" for quite a while now, and finally getting to the finishing touches. I am looking for some 1.5" or 1.75" stainless steel tubing to make the exhaust. I have been trying to do it with handicap handrails from bathrooms, but it is too thin. When I am welding it, it seems to be difficult to get it polished out without going through the pipe. Also filling small imperfections turns into filling a large hole in the pipe. I am learning how to weld stainless, and it isn't easy, but I think my downfall is from the thin material I have to work with. The clincher is that I also need madrel bent 90 degree elbows, smaller radius' preferred. Anyone know a good source for any of this?
  2. Beau
    Beau
  3. Willy301
    Willy301
    I have googled, Yahoo'ed and Bing'ed until my fingers bled out, or I would not have brought it before you. I even checked McMaster Carr...I am not a noob here.
  4. Beau
    Beau
    Interesting. It took me about 30 seconds. Everything you asked for seems to be available in the Jegs link I posted.
  5. Willy301
    Willy301
    I work at Jegs, they do not offer Stainless in 1.5 or 1.75...they start at 2 inch and go up.
  6. Beau
    Beau
    You should tell your employer to update their site.
    http://www.jegs.com/i/Stainless-Works/842/MB90175/10002/-1?parentProductId=755759
    Stainless Works #842-MB90175
    Stainless Steel 90° 1-3/4'' Exhaust Bend
    Ships Monday
    http://www.jegs.com/i/Hooker+Headers/520/32550/10002/-1
    Hooker Headers #520-32550
    Mandrel J-Bend - Stainless Steel
    Tube OD: 1-3/4''
    Radius (R): 2-1/2''
    A: 6''
    B: 15''
    C: 3-1/4''
    .049" Wall Thickness
    ships Monday
    http://www.jegs.com/i/Patriot+Exhaust/737/H7704/10002/-1
    Patriot Exhaust #737-H7704
    Stainless Steel Exhaust Tubing
    18 Gauge
    1-3/4'' Tube Diameter
    5' Length
    Ships Monday.
  7. Willy301
    Willy301
    I stand corrected, it must have been recently added to our inventory, been watching it close, but not close enough. Thank you.
  8. 48FordFanatic
    48FordFanatic
    from Maine
    And for what its worth , most stainless steels are non-Magnetic.
  9. Marcosmadness
    Marcosmadness
    Burns Stainless is another source.
  10. 37RAT
    37RAT
    from Wisconsin
    I always use SS Dairy tubing and elbow's, 16 guage. You can get it in several different sizes, are there any dairy supply outlets in your neck of the woods?
  11. saucerhead
    saucerhead
    Try Stainless Works in Ohio and ask for 16 ga. tubing. Also in south Michigan google
    Wolfes aircraft supply, good stuff and they're reasonable.
  12. Willy301
    Willy301
    37RAT, I found a place that sells fluid tubing for those kind of bulk tanks, and I asked what they had, and he said they start at 2 inch and go up, I had not found a true dairy supplier yet. Kan't spell, I had not found them, I will add them to my source list, thanks. Saucerhead, I will now that I know about them, we just started carrying them at work, and they must have added the smaller stuff very recently. We are working to expand the website, and new stuff is on there every day... I guess I gave up and asked for help too soon. And to the others, thanks for the help, I had been watching the Hooker products, the small diameter stuff had to have been added within the last few days! I will call Stainless works direct to see if I can source some straight pieces.
  13. metal man
    metal man
    If you want to keep it local, go to Tubular Techniques in Hilliard. They have what you need (614) 529-4130
  14. supervert
    supervert
  15. DERPR30
    DERPR30
    from HARVEY LA
    U may try marmon keystone they have locations all over us
  16. Mr48chev
    I don't know about your area but we have at least one scrap dealer in this area that sets aside some of the nicer stainless scraps he picks up from fab shops in his scrap bins and sells it by the lb. Sometimes the fab shops will sell remnants for a reasonable price too if there is one in the area that will sell them or sells metal along with what they fabricate.
    I used to do the maintenance purchasing for a big apple/grape juice plant and getting stainless remnants wasn't an issue but the outfit who I sold the scrap to would resell some of it by the pound if a guy got there before they bailed it. A guy has to be resourceful and hunt around a bit.
