Projects Southeast Gassers 65 Comet Super Stock Wagon
Discussion in 'Traditional Hot Rods' started by southcross2631, Oct 28, 2020.
  1. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    The ******* Bunny would be more period correct!;) lol Larry
    hotrodjack33 and loudbang like this.
  2. southcross2631
    southcross2631
    For you maybe. Not my style.
  3. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Hope I didn't offend, I just remembered that silly bunny head being everywhere back in the day! Larry
  4. hotrodjack33
    hotrodjack33
    What the hells wrong with you Larry...it's a school bus for ****s sakes.
    You certainly don't want to distract the children away from their "cop-hating rappers" and their "murder -filled video games. :eek:;)
  5. southcross2631
    southcross2631
    No offense taken. Just never cared for the magazine or the owner of the company.
    Yes the symbol was everywhere back in the day. I think they even did some race car sponsorship.
    Back to the car. While I am waiting on the rear end parts I have been cutting and buffing the paint.
    A lot of work, but worth it .
    Getting ready to order a Theunderbolt tear drop for the hood. It will allow me to build a big enough air box to run the 5 inch hose to the carb or 2 carbs if I can save up enough money for the manifold and 2 more carbs.
    alanp561, bchctybob, AHotRod and 8 others like this.
  6. Joe Travers
    Joe Travers
    from Louisiana
    Do rules allow tunnel-ram intake?
    Joe
  7. southcross2631
    southcross2631
    I wish, but no it has to be a dual plane. Blue Thunder makes a high rise 2x4 intake that takes Holley carbs. It is $ 645.00 and that is not in the budget at this time. Plus I would need 2 carbs and linkage and fuel lines.
    With (2) 1 inch spacers it would be like a mini tunnel ram. It would probably boost my top end power by 30-40 horsepower over what I have now.
    I am going to see how it goes next weekend in Alabama. If the car hooks like I hope it will I may go to a 6.33 gear to wring it's neck a little tighter to get some more out of it.
  8. tpw35
    tpw35
    Ive got the thunderbolt hood off of my car that we arent running, it has a hole cut in it that our stacks stuck through but it could be patched, if you think you could make it work Ill cut you a deal on it.
    Todd
  9. southcross2631
    southcross2631
    i answered your PM.
  10. southcross2631
    southcross2631
    Got a call from Hudlow's this morning. Going to pick up my axles and spool tomorrow morning.
    Hopefully our t shirts also.
  11. Mike Colemire
    Mike Colemire
    You'll be able to up it a few rpm off the line when you get them!:)
    loudbang and Thor1 like this.
  12. 51504bat
    51504bat
    T shirts or axles?:cool:
  13. southcross2631
    southcross2631
    Both ! Those t shirts are worth at least a tenth. I plan on bringing out hard with my new set up if it works the way I hope . Just in case we are taking the ******* bars and I can have them on in about an hour. So we will make a p*** on Friday night to check it out. That will give me all day Saturday to bolt them back on and put the weight back in.
  14. oldiron 440
    oldiron 440
    I just watched the video of Holt Florida and your car spends so much energy pushing the rear suspension down, You need to get the instant center out farther. I don't think springs alone will help, are you going to install the Caltrack bars or ladder bars maybe a four link?
    If you watched all the other cars, body lift isn't as severe or as violent as yours.
    bchctybob, loudbang and chryslerfan55 like this.
  15. oldiron 440
    oldiron 440
    I'm curious about how much air pressure you run in your slicks? Drag radials have problems like this because they run a higher air pressure than slicks. The higher air pressure makes the tires bounce on the hit.
  16. oldiron 440
    oldiron 440
    I have an OT street/ strip mopar that has 60' times in the 1.3 second range.
    I believe that the problem with your rear suspension is the location of the front spring hanger. 20210501_022126.jpg
    If you were to lower the spring hanger by 2" it will move the instant center forward and lift more toward the front of the car, this will take away the radical lift you are experiencing but still give you enough to plant the tires. If you have ajustable shocks you can slow down the extension. But I believe that the spring hanger will change what has been going on.
    If you do use the ******* bars extend them so they contact the spring eye.
  17. southcross2631
    southcross2631
    This is what happens when it doesn't hop.
    Got my axles and spool. 20210417_143152.jpeg 20210430_152846.jpeg 20210430_161255.jpeg
    Sent from my SM-A505U using The H.A.M.B. mobile app
  18. southcross2631
    southcross2631
    Got the rear end back together yesterday on my break from work. I need to fill the rear with fluid so I can check the ride height to see if I need to make spacers. Hope not, but that's just part of it.
  19. southcross2631
    southcross2631
    Good news. I got the car back down on the ground and with the tires set and me in the car I gained an inch of ride height in the back.
    Now when I take the weight out it will be good to go. I am figuring on being able to take out about 65 lbs of ballast . I lost 25 lbs in just the weight of the springs. Then I added the pinion snubber and removed the ******* bars. I will have to weigh the car and then start adjusting when we get to Alabama and run across the official scales.
  20. southcross2631
    southcross2631
    The t shirts are here ! We went to Chattanooga yesterday and picked them up.
    Going to continue with the cutting and buffing today.
  21. Junior Stock
    Junior Stock
    Watched the finals from Shadyside. Seems they are getting a little carried away with the hood scoops.
    Starting to look more like Modified Production than Super Stock. HaHa
  22. southcross2631
    southcross2631
    I know what you mean about the hood scoops. the Dirt Man team cars all are running 440 sixpack hood scoops which are not period correct and the other Comet is running an oversize Boss 429 hood scoop.
    I tried to get them to loosen up the intake manifold rules so it would be more like Modified Production, but keep the spec tire rule. I would love to see what my car could do with a tunnel ram and and 2 660's.
    I am still looking for a dual quad Holley inline intake for my car. It is a hard pill to swallow buying a $ 650.00 intake and then start porting it . I know that on somebody's shelf in their garage is an old dual quad intake that they haven't ran in 25 years. I will find one .I just have to be patient.
  23. bchctybob
    bchctybob
    I've got this F-28 on the shelf if it would help. I think it's brand new, doesn't look like it's ever been used or molested. I think it's for the 289-302. I have no plans to use it, PM me if you want it.
    chryslerfan55, EVL401, Thor1 and 6 others like this.
  24. southcross2631
    southcross2631
    Talked to Edelbrock's tech line and they got a kick out of what we were doing in the super stock cl***.
    They didn't have a clue that we even had a super stock cl***. He told me I really need a tunnel ram. I told him that I know that ,but we can't run one so would the F-28 manifold work.
    He said a lot of porting would be needed.
  25. glrbird
    glrbird
    Anyone in your area doing extrude honing?
  26. southcross2631
    southcross2631
    I spent some time with some very knowledgeable ford people yesterday and they said the only manifold they would use would be the Blue Thunder with 2 Holleys.
    chryslerfan55, ottoman, Thor1 and 4 others like this.
  27. southcross2631
    southcross2631
    The car really liked the Calvert springs and my 60 ft. times showed that , but it is time to pull the top loader out and file the burs off the shifting lugs. I had to get completely out of the the gas to get it to go into the next gear. In fact my last p*** it never came out of second. and I was forced to just push the clutch in and coast across the finish line.
    I will be pulling the transmission today. Anybody want to step up and buy me a Gforce or Hightower.. I will give you a t shirt and your name on the car. :)
  28. southcross2631
    southcross2631
    Forgot to post this really cool picture. I didn't realize I had my phone in my pocket.
    We were waiting to make our first p*** on Saturday. I took it while we were getting ready. Also here's one of my buddy fiddle picker out the side window. 20210508_135027.jpeg 20210508_135043.jpeg
    AHotRod, chryslerfan55, brEad and 7 others like this.
  29. Budget36
    Budget36
    Lol. If I had the spare cash I’d send ya a g force.
    What did you get your 60 down to?
    Seems like you about are where you want to be.
    chryslerfan55, Thor1 and loudbang like this.
  30. southcross2631
    southcross2631
    Not quite. I still need to be around 1.55's I am now at 1.69 ,but that's better than 1.90 where I was.
