Hot Rods spark plug heat range ??
Discussion in 'The Hokey Ass Message Board' started by putz, Sep 5, 2025.
Tags:
  1. putz
    putz
    from wisc.
    I have a SBC 283 bored to 302 , 305 heads , slight Engle cam , hei dist. Edlebrock 600 cfm , need advice on what plugs and heat range ...
    chryslerfan55 and MAD MIKE like this.
  2. 19Eddy30
    19Eddy30
    from VA
    ***uming 305 Non Vortec heads ,?
    Flat top or dome?
    Flat top ac 45 ts 9-10 :1
    Gap 40-45
    10:5 -11ish I would say ac 44
    I more likely also start with 15-18 deg
    Of Initial total on mechanical advance
    Set around 34-38 total to start off with.
    Notes to fine tune ,
    Use Ngk Chart & cross for
    Heat ranges
    putz likes this.
  3. lake_harley
    lake_harley
    AC 44 or 45 plugs (I'm on vacation and can't remember exactly right now) in my FED. Mild cam in an otherwise stock 305 running a TorkerII Edelbrock with a 600 Holley and HEI with vacuum advance eliminated, lightweight mechanical advance springs with 36° total timing. It's been working fine racing it for 3 years now.
    Lynn
    putz likes this.
  4. squirrel
    305 heads take a "peanut" plug, so R45TS would be a good place to start.
    putz likes this.
  5. peanut?
    Ben
  6. squirrel
    5/8" hex tapered seat, vs the older 13/16" hex gasket type
    The letter T in the AC part number tells us it's tapered seat. Chevy started using them in most engines starting in 1970 model year.
    HemiDeuce, jimmy six and putz like this.
