Spark plug shimming help
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Jan 14, 2010.
  1. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    So iv been having this issue with my flathead 6, it rad good first time i fired it, and has ran like shit ever since. I was thinkin mabey the carbs were flooding out. Well, i yanked the plugs to see if they're wet, and i found that they all had a gap similar to a piece of paper, and you can see where the valves had been tapping on the ground strap. Not enough to close them completely, but any mechanical interference is bad. I put some copper washers on the bottoms of the plugs to raise it bout a 32nd of an inch, but i may have to go more. Motor is a 230 plymouth, plugs are champion H10s.
    Any advice?
  2. plym49
    plym49
    from Earth
    Wrong plugs (too much reach into the chamber)?
    If the valve hits up solid it could kill your timing gear. Happened last year to one of the guys here.
  3. parklane
    parklane
    See if you can get the same heat range plugs that are shorter inside the engine. Do the present plugs have a extended tip?? A jobber that's got something on the ball should be able to help you out on this.
  4. Fenders
    Fenders
  5. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Ok, so i searched Champion, and they say use a Rj12c, 14mm, 3/8 Reach, while the RH10c is a 14mm 7/16ths reach.
    off to the autoparts store tomorrow.
  6. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    No, the plugs go in over the valves. Its a rebuilt motor.
  7. Fenders
    Fenders
    The autolite 4S-140 is also 14 mm 3/8 reach. Use what you can find.
    http://www.oldengine.org/members/diesel/Plugs/equiv.htm
  8. Last edited: Jan 14, 2010
  9. Sorry I had to do some editing there because the first time I posted it the links would not work. Paul
  10. Your are right my brain and fingers are not connected and I should have left the Y off.
    UJ12 is the right one
  11. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    So just a UJ12, and ill be good? Thanks for the help fellas
  12. gimpyshotrods
    gimpyshotrods
