Technical Spark Plug Wires Assembly
Discussion in 'Traditional Hot Rods' started by bandoola, Mar 8, 2025.
  1. bandoola
    bandoola
    Can someone either talk me through or direct me to a video detailing the proper way to ***emble the threaded, non-boot, ends on the cloth covered spark plug wires?
    Thank you
  2. bandoola
    bandoola
    I believe the ends are possibly Rajah
    Toms Dogs likes this.
  3. squirrel
    I believe you strip off just a little bit of the insulation, put the outer housing over the wire with the threaded end "out", and the wire extending just to the bottom of the threads. Then screw in the metal end, it should spread out the wire strands as it finishes threading in place. Might take a few tries to figure out the exact amount of stripping needed, and how far to push in the wire.
    Pictures of what you're working are always a big help so we can see for sure. Good luck.
    Pist-n-Broke likes this.
