spark plugs
Discussion in 'The Hokey Ass Message Board' started by e z i, Dec 16, 2008.
  1. e z i
    e z i
    I hate to sound like a dumb ass, but i need a recommendation on spark plugs for my newly acquired 1935 Ford tudor sedan. it has worn out has Champion UD-16's, and I need to replace them, But I'm not sure what I should use. Is this the correct plug for the car? Is there something better I should be using?
  2. kenagain
    kenagain
    from so cal
    check fordbarn for that info those guys no fords better than anybody on stuff like that
  3. Dowies
    Dowies
    I'm running a 39-42 Ford flathead with Autolite 216 plugs. The Champion comparable is CHA844-1 or H10C. I find that the Autolite 216 is easier to find.
    The thread for these plugs are M14 - 1.25mm X .375".
  4. Petejoe
    Petejoe
    from Zoar, Ohio
  5. flathead daddy
    flathead daddy
    Second on the Autolite 216s. I've had trouble with the new champion H10 plugs, but if you can find an old set they work well too.
  6. flathead daddy
    flathead daddy
    Sorry... this is assuming you have a stock flathead in your '35
  7. e z i
    e z i
    Yea, it's a stocker. thanks everyone for your input.
