Spark Plugs???
Discussion in 'The Hokey Ass Message Board' started by strombergs97, Jan 21, 2009.
  1. strombergs97
    strombergs97
    Ok, my 241 Red Ram in now broke in. I just bought a MSD 6a ignition box, that I want to install. I have pertronixs guts in my dizzy and using a Flame Thrower coil (pertronixs)..I want to know what is the best and hottest spark plug to use, and what gap should they be set at....
    The engine has 3x2 intake w/97s, Sanderson headers, oversize valves, if thats any help..
    Thanks
    Duane..
  2. Hank37
    Hank37
    Plug heat range depends on compression your running, cam etc. On my Caddy I'm running 12:1 comp. so the only plugs I can use are AC 42-1 these are the coldest plugs I can get and they run a light tan color. I have a Jacobs Energypak system with dist . using Petronix Iginter. Also plugs are gapped to .055"
  3. kman1932
    kman1932
    Hi Duane, I"ve got a 58 392 hemi (blown). I'm running a msd 6al with blaster 2 coil. I've had real good luck using ngk bpr5es plugs gapped at .045". They burn real clean and last along time. No problem with misfires. That would be a good starting point. You might want to try one step hotter. Hope that helps. Chuck
  4. 73RR
    73RR
  5. strombergs97
    strombergs97
    OK, what I have found is NGK XR4 and NGK XR4IX. I'm not sure which one.
    Duane..
  6. moparjack44
    moparjack44
    I have been running autolite 65 plugs, which is what I ordered, but they sent me ngk bpr5es plugs. Are the ngk bpr5es OK?
    The engine has slight bigger cam and low compression , 2 4s 500 cfm edelbrock? It's a driver not a race car.
  7. 19Eddy30
    19Eddy30
    from VA
