Spark? problem; or, i swear i am going to kill my truck with me in it.
Discussion in 'The Hokey Ass Message Board' started by general gow, Jan 14, 2009.
  1. general gow
    general gow
    MODERATOR
    the firing order is correct. the wires are 5 years old, only not really used. but when i move them around, i can tell a difference in the way the car idles, and sometimes it causes a misfire. so i suspect a few are bad on the inside. new wires tonight i hope, as long as it is above the 7* it is right now.
    i have made huge progress though. yay.
  2. OldBuzzard
    OldBuzzard
    That truck may have been designed to use real wire and not the graphite covered string that is todays "resistance wire". Might be worth checking on.
  3. keith novak
    keith novak
    check too make shure u have srark when cranking for a monment if not you have a bad key switch too make shnure put a wire from batt pos to coil pos then start keithnovak
  4. general gow
    general gow
    MODERATOR
    buzzard, i'll have new ignition wires tomorrow, so i'll let you know. special ordered from napa as 'factory replacements'. so we'll see what they give me.
  5.
  6. general gow
    general gow
    MODERATOR
    been super cold again here. no time in the driveway.
    i did find good replacements and returned the universals. should get them on this weekend.
  7. LeadSledMerc
    LeadSledMerc
    What the hell are you talkin about, Mark...we've been having a frikin heat wave the past couple of days.
    Get off the computer and take the 5 minutes to get those new wires on today. If not, you'll be freezin your balls off doin it this weeknd!:D
  8. general gow
    general gow
    MODERATOR
    ah well, when we have sunshine and warm weather i am 50 miles away from the truck, inside working for the man. so the freedom isnt really there to do that...
  9. LeadSledMerc
    LeadSledMerc
    That's OK, your girl already believes "it's shrinkage"!! haha:D
    Let us know how you make out.
  10. rustyford40
    rustyford40
    from Mass Bay
    Shrinkage and not knowing if you can get it started. What can be worse.
  11. general gow
    general gow
    MODERATOR
    well, i got the new wires on. and i hate to admit it, but i think don might have been right all along...
    definitely needs a new ignition switch.
  12. general gow
    general gow
    MODERATOR
    but then, all i need is to get the wheel cylinders in on all corners and it'll be ready to go.
    and what the heck were they thinking with left handed lug nuts on the left side of the truck? good grief.
