Technical Sparkplug Tap size for 49-53 Ford Flathead?
Discussion in 'Traditional Hot Rods' started by ChopTopJimmy, Oct 5, 2013.
  1. ChopTopJimmy
    ChopTopJimmy
    Quick questions. What is the Sparkplug Tap size for 49-53 Ford Flathead? Tried a search on here with no luck. Just wanting to clean up the threads prior to install. If i need to repair any of the plug holes, where can I find the repair kits? Also, where is a good source for a head stud kit? Thanks in advance, CTJ
  2. gkgeiger
    gkgeiger
    They have 14MM thread and I wouldn't use a tap but a thread chaser instead.
  3. Dale Fairfax
    Dale Fairfax
    Use a small diameter cut-off wheel and cut a vertical slot thru the threads of an old plug. Only about thread depth and bias the slot so one edge wants to cut when turned into the hole. Sorta like a single flute tap but it won't remove any metal.
  4. get one of these , a few bucks at any auto parts store...has 14 and 18 MM
  5. 29AVEE8
    29AVEE8
    Thats the way my Dad taught me to do it. Same thing for head studs to clean out the block, never use a tap.
  6. ChopTopJimmy
    ChopTopJimmy
    Thanks guys. Good advice. Any help with where to buy a head stud kit? Thanks again, CTJ
  7. 40FordGuy
    40FordGuy
    What 36 said .
    4TTRUK
