Technical Speaking of oil:) does it go stale/etc?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Apr 6, 2023.
  1. Budget36
    Budget36
    My dad always bought 55 gallons of Dello 400 when he was driving his trucks. He retired around ‘02 maybe?, anyways I’ve used some of here and there. Tractors, etc. probably have 15 or so gallons left.
    My neighbor is going to be firing up a fresh flat tappet rebuilt SBC in a few weeks.
  2. Shelf life is 60 months from the fill date printed on the label. I would not put 20 year old oil in a new engine.
  3. Budget36
    Budget36
    Heck, it probably older than that too.
    Thanks.
    Desoto291Hemi and lothiandon1940 like this.
  4. All the stuff Chevron added that makes that oil great is probably out of suspension and at the bottom of the barrel.
  5. Hutkikz
    Hutkikz
  6. lothiandon1940
    lothiandon1940
    hrm2k likes this.
  7. 210superair
    210superair
    from Michigan
    "my wife said our kids are spoiled. I told her they all smell like that."
    - Rodney Dangerfield
    I wouldn't use old or used oil in anything I cared about. In something I didn't give two chits about? Sure. Why not.
  8. Rand Man
    Rand Man
    I would use it on my stuff. They could be right about the additives out of suspension, but I’m not exactly sure that’s how that works, would like to see the data. The thing is, oil companies don’t have a reason to do that type of testing. They’re in the business of selling new oil. Bottom line; I wouldn’t give it to a friend.
    Budget36 likes this.
  9. buds56
    buds56
    I was give 2 cases of E**on 10-30 oil by my neighbor when they tore down their shed, they were at least 25 years old.
    I used them up ( I did shake them up before I opened them) with no ill effects in a Pontiac engine I had just rebuilt.
    Just my experience
  10. Budget36
    Budget36
    I haven’t pumped out of it in at least 10 or so years. I’d just stopped at the neighbors place on the way to work and while talking the subject of diesel oil came up for his engine. I told him I still had some left from my dad.
    I didn’t have time to do googling at work, but will see him this weekend and let him know.
  11. 37gas
    37gas
    $50 to go get your oil changed at local shop, new oil, new filter , no mess to clean up or oil to get rid of . Or use 20 year old oil for free and maybe get to change your cam and lifters. I'am not going to take the chance that It's no good but that's just me .
    210superair likes this.
  12. Budget36
    Budget36
    Would be tough to shake up a 55 gallon drum;). But I get ya.
  13. Budget36
    Budget36
    Well, he was wanting it for start/fire up.
    Also, much cheaper for you at a drive through place, in my humble Ca City I’m in, my daughter paid 90 bucks a month or so ago did her 4cyl commuter.
    I’d just offered it up to him and got to thinking about it.
  14. chessterd5
    chessterd5
    from u.s.a.
    Oil never loses its viscosity. Or simply, it's ability to lubricate. But contamination is a different issue. Condensation inside a closed container, dirt, rust from the barrel. Etc., etc.
    I think the answer has already been given. If I did use it in something I wasn't concerned about maybe I would strain it through a large coffee filter.
    reagen, 210superair and Budget36 like this.
  15. squirrel
    Not for a new engine, but for an old beater, no problem.
    I recently got several quarts of oil in paper quart cans, it'll go into one of the old cars I play with for LeMons Rallys, etc.
    I did that before, with no ill effects....
    mrspeedyt, LOST ANGEL, Lil 32 and 6 others like this.
  16. stanlow69
    stanlow69
    Cap off the barrel and roll it around. That`s how I shake my full 5- gallon buckets of glue. I just roll the can up and down the alley.
  17. indyjps
    indyjps
    I'd run it in a "driver". hi rpm stuff, I'm more particular about.
    Budget36 and SS327 like this.
  18. lostn51
    lostn51
    from Tennessee
    This does raise a good question because now that I think about it I have at least 150 quarts of non detergent SAE20 and SAE30 weight oil in my garage that dad bought 20+ years ago. He would buy it when he saw it on sale or on a close out @ Kmart or something an am***ed a plethora of the stuff. All he used it in was his flatheads and the lawnmower so I guess it’s still good…….Any opinions on this?
  19. jimmy six
    jimmy six
    Blues4U should chime in here…
    We tested our oil at work at large power stations in So Cal. We also made filtering systems and bought others. Our oil guy would always take samples of new oil from 55 gallon drums taking a 1/2 quart in a gl*** sealed container and set on a shelf. In a month or so there was always sediment on the bottom. Blackstone tests on new oil was sometimes worse than the tested oil we filtered that had been in use for over a year.
  20. stanlow69
    stanlow69
    Oil is over a thousand (more than that) years in the making. Can it go bad? @Blues4U
  21. RmK57
    RmK57
    Rig up a long shaft paint mixer and let er rip.
    Beanscoot, theHIGHLANDER and Budget36 like this.
  22. alanp561
    alanp561
    The more I read, the more I believe that the Frantz oil filter system might not have been such a bad idea, after all.
    6-bangertim, Budget36 and caseywheels like this.
  23. Blues4U
    Blues4U
    from So Cal
    Yes engine oil does have a shelf life, as others have already pointed out it's due to settling of some of the additives, as well as condensation build up as @chessterd5 mentioned. Drums definitely breathe air through the bungs, even brand new sealed and never opened bungs will breathe; and if sitting outside with rain water collecting on the top, they will pull water into the drum. But even if they are kept under cover out of the elements in a humid environment water in the air will condense as temperatures drop overnight. Over 20 years time period there's liable to be quite a bit of condensation built up in that drum, unless you live in the desert.
    I wouldn't use it except in lawn mowers and old oil burners with a lot of miles on them that really don't care so much about what type of oil they have, as long as they don't run out.
    @squirrel you probably could've sold that old can of Castrol to a collector for enough to buy a new bottle of oil! :D That's a great photo though.
  24. CSPIDY
    CSPIDY
    *****hose
    Budget36 and chessterd5 like this.
  25. alanp561
    alanp561
    Changing your *****hose at every oil change sounds unsanitary to me but, you do what you want ;).
  26. lostn51
    lostn51
    from Tennessee
    I prefer thigh highs myself but……oh wait……wrong forum…..:oops:
  27. jaracer
    jaracer
    Years ago I worked for a filling station that was owned by a company that sand blasted buildings. They had a number of air compressors powered by 4 cyl gas engines. When we would service the engines, the oil that came out of the compressor portion, 3 or 4 gallons, always looked like new. My buddy would save the compressor oil to run in his old cars. He said for safety's sake he would let the oil set for at least a month to let any sand drop to the bottom.
    indyjps and Budget36 like this.
  28. 210superair
    210superair
    from Michigan
    Hey man, whatever you guys wanna wear is cool, but yeah, don't post pics please.... Lmao
  29. CSPIDY
    CSPIDY
    I understand that petroleum based oils and their additives break down over time
    but recently the cans for aviation full synthetic oil used in jet engines have been stamped with a shelf life date???
    Some of the engines this oil is used in require no oil changes between overhauls
    Which can be 5, 10, 15, 20 years and the manufacturers of the engines have no calendar replacement time on the oil either
    It’s total BS
  30. lostn51
    lostn51
    from Tennessee
    So for what I’m gathering a non detergent oil that’s been sitting for decades I can filter it through something to get the particulates out of the oil and run it in my flattie without killing the bearings
