Technical speaking of tachometers, Star 2"?
Discussion in 'The Hokey Ass Message Board' started by Paul, Jan 16, 2025.
  1. Paul
    Paul
    Editor
    I have had this little Star 2" tach in my stash for a while, again online searches turn up little information on it.
    I will be testing it soon to see if anything happens but,
    anyone here familiar with these things?
    12 volt? negative ground? how many cylinders?
    it has the four leads out the back, red, green, black and white and what looks like something meant to adjust.. factory set potentiometer?
    any input appreciated
    PXL_20250117_053214885.jpg PXL_20250117_053243274.jpg PXL_20250117_053254864.jpg PXL_20250117_053258997~2.jpg
  2. tubman
    tubman
    Well, white is obviously the light, so that probably conforms to the usual pattern. The probability is overwhelming that it is 12 volt negative ground. (That is, unless there is a corresponding transmitter box that you don't have. Chances of that are slim to none.)
    lothiandon1940 and Paul like this.
  3. Kerrynzl
    Kerrynzl
    Standard aftermarket tachometer wiring is
    Red = 12v + switched
    Black = Ground -
    Green = Negative side of the coil signal
    White = Lights
    This also applies to rev limiters, RPM switches, shift lights.
    And you can connect multiple devices parallel.
    So connect it up parallel with another tach to check the accuracy.
    rod1 and Paul like this.
  4. Dedsoto
    Dedsoto
    from Australia
    globe should have voltage and wattage on it
    Paul likes this.
  5. RodStRace
    RodStRace
    I took a look at that link I posted in the other thread to see if they had this one too. No luck. :(
    They do offer service and repair, but have no idea what it costs and how much you value the tach.
    If you want to dig in, they do have a number of tech articles on tachs. You could educate yourself on standard designs and practices. With that and a DVOM, you might poke around and find a bad circuit or component.
    I tried a few searches trying to find other examples or a company. One was from the 80s to the 90s.
    https://opencorporates.com/companies/us_ma/042083501
    This is the other, dissolved in the 50s. Both were in MA. Don't know if either are the actual source.
    https://www.bizapedia.com/ma/star-gauge-company-inc.html
    porkshop and Paul like this.
  6. Paul
    Paul
    Editor
    thanks,
    that's what I would expect too
    12 volt, negative ground, gas engine, point style ignition, common wiring color connections.
    if anything happens when connected simple math when compared to trusted tach's numbers should show how many cylinders it was meant for.
    just curious if anyone here was familiar with the 2" Star
    RodStRace likes this.
