Speedo Cable Bend
Discussion in 'The Hokey Ass Message Board' started by seb fontana, May 9, 2013.
  1. seb fontana
    seb fontana
    from ct
    How sharp of a bend can a speedometer cable handle? Would a 5" radius be acceptable? Actually have four bends, doesn't feel like too much drag at the trans gear..
  2. XXL__
    XXL__
    I broke a cable trying to run a similar radius. It worked for a while, but you could hear it rubbing the jacket if you listened closely and the needle had a bounce at low speeds. Eventually, it twisted off the end. I rerouted to reduce the bend, but am considering a right angle fitting... but they are pricey for what they are.
  3. Rusty O'Toole
    Rusty O'Toole
    Let the cable d**** into the largest radius curves you can. Basically let it go where it wants, do not force it into position any more than you have to. It will work better and last longer. Instead of 4 bends try to get one big curve.
  4. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Ive had cables wear out quickly from radiuses like that. Use angle adaptors if needed, beats a speeding ticket.
  5. e1956v
    e1956v
    Alliance Vendor
    5'' is pretty tight, like the other guys said in their post the larger radius of a bend the better.
  6. Motomike43
    Motomike43
    I would say 5 " is your MIN radius BUT only if your running it at 90deg or less. any turn over 90deg then I think your pushing your luck. I have never seen something like that cause any problems other then a jumpy speedo needle, Noisy cable or broken cable end.
  7. hoop98
    hoop98
    from Texas
    20x the housing od.
  8. seb fontana
    seb fontana
    from ct
    Thanks guys..not what I wanted to hear but while I have the steering column out, and the front seat out...............
