1952-59 Ford speedo cable
Discussion in 'Off Topic Hot Rods & Customs' started by Slicks, Sep 5, 2010.
  1. Slicks
    Slicks
    from denison tx
    Does anybody know what cable works with c4 and stock 55 ford speedo maybe somebody might have a good part number
    thanks slicks
  2. Y-Blockhead
    Y-Blockhead
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Get a 69-73 Mustang 302 or 351W cable,NAPA should have it in stock.
  4. exactly what jeff said.. i bought mine at advance auto for $13..this was after i spent $75 on the lokar cable that came out of the bracket and melted on my exhaust.. for $13 i'd buy 2 or 3 of them.. fyi..they are a little short so route it the best you can.
  5. 54HotRod
    54HotRod
    will this also work for the c6 to stock 54 speedo?
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    The C6 is a little longer,a cable from a Torino same years should work just fine.
  7. 54HotRod
    54HotRod
    Jeff you amaze me with how simple these answer are to you. You are like a human google for car information.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    When I was a young boy I marveled at the things my Norwegion Grandpa could tell me about life,He barely had a sixth grade education and when He was 14 went to work in the lumber mills in Northern Minnesota and the Mesabi Iron mines came down to the Twin Cities and drove street cars in His 30's met my Grandmother and they opened a restaurant together.When I asked Him why he knew so much,He said"every day you learn someting, put dat in da head and keep dat for later someday you vill be older and visor too" He also told me "education is good to go in one ear but too much makes common sense go out the other ear" So as you all read the knowledge shared in this in this forum,keep it stored away.
  9. 54HotRod
    54HotRod
    I will definitely do that, thanks again
  10. Vicky
    Vicky
    from Norway
    JeffB2! Your Grandpa was a great and smart man!
  11. Slicks
    Slicks
    from denison tx
    got cable today had to order it came with wrong speedo end ordered again today this is the way this project has gone owell more later
  12. Baggs
    Baggs
    could i use that same cable on my 54 with the aod??
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    Some AOD's are different,I had a cable made at ****'s Speedometer here in Phoenix I took Him the AOD end and the old '54 cable it ran $60 total.
