Hot Rods speedo not working
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, Aug 24, 2024.
  1. 29moonshine
    29moonshine
    i have a 350 turbo that the speedo is not working .if i put a drill on the cable at the transmission the speedo works on the dash. if i take the cable off at the dash and put a drill there with the gear on the cable the gear will turn out of the transmission
  2. big duece
    big duece
    from kansas
    The plastic drive gear may have broken, or the metal tab that keeps it in place has failed.
  3. squirrel
    or the driven gear may have broken, or stripped, or have a stripped square hole in it, or parts could be missing, or the wrong ones.
    Take the bolt out, remove the "bullet" sleeve that holds in the driven gear, see how it all looks
  4. Happydaze
    Happydaze
    Do you know if it has ever worked, aka what's the history of the trans?
    Chris
    Desoto291Hemi likes this.
  5. 29moonshine
    29moonshine
    well when you have a shop rebuild your transmission you would think they would put a gear in the transmission so the spedo would work. but they did not.
  6. squirrel
    they'd have to know what gear to put in it, eh? so it's not real surprising they left it out, the installer is supposed to deal with that.
    twenty8 likes this.
  7. 29moonshine
    29moonshine
    thanks i did not know that. i thought they would have put one on the shaft inside the transmission .now i have to pull the tail housing to put one on
  8. big duece
    big duece
    from kansas
    Find out your gear ratio, and tire diameter... TCI site used to have a calculator that would figure which driven gear you need with your drive gear, vic versa. Depending on your combo, the drive gear could be one of several tooth counts/colors.
  9. squirrel
    What I meant was that you have to sort it out before you install the transmission. At least, I always do....
  10. Wait a minute,,,,there is no gear inside the housing on the main shaft ?
    Yes,,,,I would expect the shop to install that on the shaft,,,,,,you are only responsible for the driven gear inside the “bullet “ .
    Tommy
    bill gruendeman likes this.
  11. ClayMart
    ClayMart
    Do you or the transmission shop still have your old, failed transmission available? You may be able to swap the drive gear out of your old transmission. Are the old and new trans both TH350s? Even if the gears may not swap between different transmission types, you may still be able to determine the tooth count of the drive gear that had, I ***ume, worked previously. The color of the drive gear may also give you an indication of its tooth count.
    big duece likes this.
  12. 29moonshine
    29moonshine
    nope. no gear
  13. ClayMart
    ClayMart
    If you were having the existing trans rebuilt I would expect the drive gear, if present and in good condition, to be reinstalled.
    If you bought an "off the rack" rebuilt trans I wouldn't expect the gear to be there. Though it would be a nice touch if they wired a tag to the trans to inform you of the missing gear.
    Did you get any printed installation instructions with the new transmission?
  14. twenty8
    twenty8
    There are several drive gear options as well, so for the trans builder to fit a drive gear would be an educated guess at best.
    I would like to think that they would at least ask the question, and install the gear you nominate.
  15. big duece
    big duece
    from kansas
    Algoma56 likes this.
  16. gimpyshotrods
    gimpyshotrods
    Unless I sent the transmission in for rebuild, I have never received a transmission with a drive gear installed.
  17. 29moonshine
    29moonshine
    well
  18. Mr48chev
    That's one that never crossed my mind but the one exchange transmission that I have installed came with the speedometer gear. That was on my mother's 75 Chevelle and she needed the car and I didn't have anyone local who did side jobs on Turbo 350's at the time. I think that one came out of Portland Transmission and I got it through Teds Auto Parts (long closed) in Top*****h.
  19. So,,,,,when you receive the transmission back,,,,,you have to dis***emble the back half and put a gear on the main shaft ?
    Tommy
  20. big duece
    big duece
    from kansas
    Yes, only way to get to it.
    gimpyshotrods likes this.
  21. squirrel
    "dis***emble back half" means removing 4 bolts and the tail housing, which is sealed with an O ring. It's not a big deal while the transmission is still on the bench or the floor.
  22. bill gruendeman
    bill gruendeman
    When you said speedo not working, I was really afraid of seeing pictures of fat old men in little swimsuits ☹️
  23. Kevin Ardinger
    Kevin Ardinger
    When I worked at a transmission shop many years ago, we would have them built on the shelf with no speedo gear on the shaft. We put the output shaft housing on upside down as a reminder and switch out the gear from the one being traded in.
  24. ClayMart
    ClayMart
    Now that's the way to do it!
    Desoto291Hemi and Algoma56 like this.
  25. ClayMart
    ClayMart
    When you're having your old transmission rebuilt, they should put the old driven gear back on.
    If you're buying a rebuilt trans off-the-rack they don't know which drive gear your vehicle requires, unless you maybe tell them the tooth count of the gear from your old transmission. Or swap it out yourself.
    Kevin Ardinger likes this.
  26. gimpyshotrods
    gimpyshotrods
    Yup. On a GM transmission, that's just a couple of bolts.
  27. 29moonshine
    29moonshine
    [you are never to old to learn] i went back to the shop that built the transmission.[he told me the same thing squirrel said]and he gave me the right gear and clip to hold it in place i guess the next time i should look before i install it
    vtx1800, ClayMart, twenty8 and 3 others like this.
  28. A Boner
    A Boner
  29. vtx1800
    vtx1800
    Here's a hint .....jack the vehicle up in the back before pulling the tail shaft housing, less fluid loss...I learned that quickly while trying to get the correct output shaft gear in the last two cars I'd built.
