Technical Speedo question on an enclosed driveshaft.
Discussion in 'The Hokey Ass Message Board' started by Petejoe, Oct 13, 2023.
  1. Petejoe
    Petejoe
    from Zoar, Ohio
    I reinstalled my driveshaft two years ago after a rear end issue I had.
    My Speedo hasn’t worked after that.
    I’ve checked my Speedo cable and speedometer with a drill and they move freely. I’ve tried different turtle gears and still no luck.
    I notice the Speedo gear attached to the driveshaft slides up and down the shaft approximately 1/2”.
    What am I overlooking here?
    Is the turtle installed the wrong direction?
    Or worse yet, is the gear in the shaft installed backwards?
    Are there different turtle configurations that would cause the teeth not to reach each other and make contact?
    The gear on the driveshaft has no free play and turns when the shaft turns.
  2. Nailhead Jason
    Nailhead Jason
    The Turtle should be bolted on so that the cable connection is on the DR side. pointing to the passenger side it would spin backwards i believe...
  3. jaracer
    jaracer
    Does it have no free play or does it have 1/2"? Is it possible the gear is spinning on the drive shaft?
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    The 1/2” free play mentioned is forward and rear along the driveshaft, there is no free play of the actual gear on the shaft as the driveshaft turns.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Opposite of my installation shown on the first picture?
  6. Nailhead Jason
    Nailhead Jason
    yes, opposite of the way it is in the first picture
    2Blue2 and Petejoe like this.
  7. BJR
    BJR
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Well I’ll be damned. Thx BJR!
    Duh….
    I don’t suppose there’s any way to access that snap ring groove without removing the driveshaft?
    Is this groove for the snap ring forward of the gear near the tranny or behind the gear??
    How about the idea of drilling a pilot hole through the gear collar and then into the driveshaft to run a threaded screw in place??
  9. Mr48chev
    That snap ring is probably going to be 17286 in this image. It also confirms what Nailhead Jason said on the direction the Turtle is installed. IMG_1224.JPG
    Petejoe likes this.
  10. BJR
    BJR
    Sorry but the rear end needs to be pulled back far enough to access putting on the the snap ring. Or the rear end needs to be removed for access. You may be able to drill in the snap ring groove and insert a roll pin to hold the gear from walking forward. But I have never tried it. Good luck, Brian.
    Petejoe likes this.
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    Thanks everyone!!
    I’ll first try turning the turtle in the correct position. Maybe I’ll get lucky and it’ll work without the snap ring. I may try drilling but it doesn’t sound too doable.
    I’ll let you guys know if I run into any luck with this. Thanks again.
  12. Nailhead Jason
    Nailhead Jason
    don't feel bad about the snap ring. When I put the banjo back in my 39, i tightened up the clam shell, went to bolt the turtle back on and realized the I left the dam gear completely out of it.......
    Petejoe likes this.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
  14. 19Fordy
    19Fordy
    Perhaps these photos of a 1940 Ford speedo set up will help.
    The speedo cable points downward on the driver side of the car.
    You can see the snap ring. Note the angular direction of the teeth.
    I aedded the top grease fill plug in the top clamshell.
  15. Petejoe
    Petejoe
    from Zoar, Ohio
    Thanks. It sure looks like my snap ring is in position comparing your pic with mine.
    My only concern is the fore and aft movement of the gear on the driveshaft. It moves close to 1/2” freely.
    Am getting ready as we speak to fire it up and see if the Speedo is working. IMG_0148.jpeg IMG_0150.jpeg
    Nailhead Jason likes this.
  16. Petejoe
    Petejoe
    from Zoar, Ohio
    No joy.
    Am again going to check the speedometer and cable to see it is operating with a drill.
    Removing the turtle and checking to see if the gear moved out of position to engage the turtle.
  17. 19Fordy
    19Fordy
    I don't see the snap ring in your above photo.
    The set up looks different than my 40.
    What year Ford vehicle are you working on?
  18. Petejoe
    Petejoe
    from Zoar, Ohio
    Am stopping for the evening.
    This is a 34 pickup.
    Here’s a pic with the snap ring being pointed to. In this picture I’ve push back the shaft gear to it further most movement.
  19. BJR
    BJR
    The one I worked on was a 32 and there was less than 1/8" play in the gear fore and aft. Did you put the shim in that goes on top of the bearing. Refer to the exploded picture of the assembly. Is the seal in place under the bearing?
  20. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes sounds like something isn’t assembled right with that much play. Time to pull the driveshaft. :(
    e1956v likes this.
  21. 19Fordy
    19Fordy
    It appears that the snap ring shown in the 1935-48 pictorial assembly drawing is not the same as the snap ring being pointed out in your photo. The 1935-48 snap ring is a thin wire snap ring that fits in a groove in the splines The item being pointed to in your photo looks like a spacer or thrust washer, not a snap ring. It would be great to see a pictorial or photo of a 1934 speedo assembly as there appears to be a difference from 1934 to 1935 -48.
    However, I did find this 1928-48 kit so perhaps I am incorrect. Notice the snap ring.
    Buy New 1928-1948 Driveshaft-Torque Tube Front Bearing Repair Kit Flathead SCTA 1932 in San Dimas, California, US, for US $33.00 (2040-parts.com)
    Petejoe likes this.
  22. Petejoe
    Petejoe
    from Zoar, Ohio
    Thx!
    Here’s the picture you referred to.
    You’re correct. I pointed to the incorrect area.
    Another close up of my assembly. The ring is actually at the bottom.
    I know more when I decide to pull the driveshaft at a later date.
  23. BJR
    BJR
    So what did you do when you had it out? Did you replace the grease seal, or just the bearing and race?
    Petejoe likes this.
  24. 19Fordy
    19Fordy
    It appears that your snap ring has been bent/damaged and not fitting correctly as it should.
    Petejoe likes this.
  25. Petejoe
    Petejoe
    from Zoar, Ohio
    It’s been a while, a few years now.
    I’m thinking I replaced it all.
    I pulled the floorboard off a few days ago to polarize the generator and decided to get back to the Speedo problem since it was open again.
    I’ll check the snap ring seat fitting before I start disassembling. Thx.
  26. 19Fordy
    19Fordy
    Be sure and take pictures of what you find so you can post them for advice.
    e1956v and Petejoe like this.
  27. wheeltramp brian
    wheeltramp brian
    On my 40 one, Ford. The gear inside the torque tube moves back-and-forth Quite a bit, but my speedo still works.
    Petejoe likes this.
  28. Petejoe
    Petejoe
    from Zoar, Ohio
    IMG_0164.jpeg Well this interesting.
    I decided to double check for speedometer function again.
    Here the thing wasn’t working.
    I disassemble the Speedo and found something quite interesting.
    This gear wasn’t engaging the workings of the odometer and speedo needle.
    There’s play in that gear moving it out of engagement. See photo.
    Installing my turtle incorrectly at the passenger side instead of the drivers side forces that gear to move in the wrong direction and moves it out of engagement.
    Going to reassemble assuring engagement and try it again.
  29. 19Fordy
    19Fordy
    Please keep us posted on your pending solution.
    Petejoe likes this.
  30. Petejoe
    Petejoe
    from Zoar, Ohio
    Success. It was a two fold problem.
    The Speedo and the Turtle position.
    I push the speedo gear at the driveshaft clear back to actually view the machined groove for the snap ring. Pushed the snap ring in place.
    The speedo is also working perfectly with its gear positional repair.
    Oneball likes this.
