speedometer cable help?
Discussion in 'The Hokey Ass Message Board' started by MERRELL, Sep 30, 2012.
  1. MERRELL
    MERRELL
    can anyone tell me what speedo cable to use,its for a 56 mercury stock speedo to c6 transmission...thanks,MERRELL
  2. Abomb
    Abomb
    I think they are pretty much universal. Go to your favorite parts store(a real one with actual catalogs on the counter ) and check both ends of a cable for your 56 and a cable for an application with a C6.
    If they're the same, just get one for a 56 mercury.
    If they're not the same, that's where the catalogs come in handy, you'll be looking for the correct length, with the proper specs at either end.
    If I walk into my local store holding two simular parts, the guys just turn the catalog rack around for me.....they're used to it now.
  3. pacoloco
    pacoloco
    Give these guys a call, I called and am having them make me a 49 Merc speedometer to Chevy 350 turbo tranny cable. The guy knew exactly what I needed, and really nice.
  4. squirrel
    probably a 56 merc speedo cable. With the correct gear for the C6 put onto the end of it.
  5. CutawayAl
    CutawayAl
    from MI
    At least some speedo shops can assemble a cable using stake-on cable ends and crimp-on cable housing ends.
  6. squirrel
    yeah, but why bother when the original cable will work?
  7. pacoloco
    pacoloco
  8. MERRELL
    MERRELL
    someones gotta have a solution...
  9. Stock cable will work fine. If you don't have it, just but one from a 60s GM. Full size like Impala then it will be long enough. I say GM because they are readily available and cheap.
  10. Dale Fairfax
    Dale Fairfax
    You've just had several solutions suggested. Have you followed up on any of them?
  11. e1956v
    e1956v
    Alliance Vendor
    The stock cable wont work, the speedometer driven gear and fitting is not the same as the C6. The C6 takes a clip on gear the Merc uses a gear with a stem, you will have to get one from a mid 60's Ford like a 65 to 68 Mustang or truck. If you want one made we can do it just give me a length.
  12. MERRELL
    MERRELL
    thanks for the info!.. i had a feeling i would have a issue with the stock cable...
  13. MERRELL
    MERRELL
    e1956v,thank you for the helpful info,i picked up a 67 mustang speedo cable and it worked out perfect!
