Technical speedometer cable
Discussion in 'The Hokey Ass Message Board' started by msgt tank, Feb 10, 2023.
  1. msgt tank
    msgt tank
    we need help finding a speedometer cable for this speedometer. the threads are on the inside. an adapter to use a modern speedometer cable would be ideal. we haven't been able to identify the brand. it has no hole in the back for a light. thanks for your help. PXL_20230202_000532323.jpg PXL_20230202_000743283.jpg
  2. e1956v
    e1956v
    Alliance Vendor
    I can make any length cable you need, PM me or hit the link in my signature to get to the website
  3. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Looks like an early Model A connection.
    msgt tank likes this.
  4. Looks similar to 47 Ford speedometer. I had my cables made by @e1956v, great service. First one had Ford transmission, 2nd one was GM, both built to connect the 47 speedo.
    lothiandon1940 likes this.
  5. manyolcars
    manyolcars
    look at Harley cables
  6. Mr48chev
  7. e1956v
    e1956v
    Alliance Vendor
    No way I can touch that price from Dennis Carpenter, my fittings cost that much.
    lothiandon1940 and Bob Lowry like this.
  8. MMM1693
    MMM1693
    I don't care what Carpenter sells them for, Rusty is the man!
  9. HOTRODPRIMER
    HOTRODPRIMER
    I have ordered 3 cables from Rusty over the years and they have all been correct. HRP
  10. fleetside66
    fleetside66
    I'll second that. I've had one of his cables running my old Wings speedo for many years & it hasn't missed a beat.
    lothiandon1940, big duece and e1956v like this.
  11. e1956v
    e1956v
    Alliance Vendor
    Thanks for the kind words guys I really appreciate it.
    Flattop Tiki and lothiandon1940 like this.
  12. wheeltramp brian
    wheeltramp brian
    I've found the "store bought" cables to be slightly smaller in diameter and will sometimes slip or wobble when spinning.ive got a local gauge repair man that makes cables.they are correct every time
  13. "Stock" cables are okay, but if you need a different end on the transmission, custom is needed. There is no hole for a single light, but it looks light slots around the back edge of bezel where cluster lighting will infiltrate the housing.
  14. Fat47
    Fat47
    Rusty at Speedometer Service is the guy you want to contact. He has helped me on a number of occasions.
  15. LOL looks like Rusty is gonna have to build me a tach cable. :D
    lothiandon1940 and e1956v like this.
  16. 51504bat
    51504bat
    Another plug for Rusty. He made the cable for the AOD in my '54 Ranch Wagon.
  17. Hamtown Al
    Hamtown Al
    Years ago I built a 29 Ford sedan that was a complete car when I got it. I disconnected the speedometer cable at the stock transmission when I removed the engine and transmission. Later, after installing a Buick V6 with a 350 turbo; the old stock speedometer cable was still hanging there so I tested it as to fitting the 350 turbo. :rolleyes:
    Wonder of wonders! It screwed right on. I used the stock speedometer in the 29 all the years I drove it using that same cable.:)
    Ya never know!
    Lucky Al that time;)
    lothiandon1940 and msgt tank like this.
  18. FiveNdime
    FiveNdime
    Does anyone know what size the threaded end is on the torque tube that the Model A speedo screws into? I'm trying to get the A speedo to adapt to the Ford T5. I can get an adapter with the 7/8 threaded cup, but cant find a 5/8 treaded cup adapter, only for the 7/8". Just trying to find out what the stock Model A cable has for the end, specifically for a 30 to 31, since those were a square cable and not an oval. Thanks
  19. e1956v
    e1956v
    Alliance Vendor
    Should be 7/8-18
    winduptoy likes this.
  20. FiveNdime
    FiveNdime
    Thanks Rusty,
    I was going to message you directly but thought since I couldn't find the information, I would post it up as a question. I guess I just need the adapter for it, simple enough. If I have trouble with anything I will reach out to you for a custom cable to be made.
