Speedometer going whacko question
Discussion in 'The Hokey Ass Message Board' started by Winged Avenger II, Jul 1, 2010.
  1. Winged Avenger II
    Winged Avenger II
    from Wisconsin
    Speedometer in my '41 Pontiac is going all over the dial. Took it out, lubed it up and it worked ok until I hit the highway and now it's jumping around. Have what I thought was a trans leak from the bearing. Could the trans be leaking from the speedometer cable??:confused:
  2. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    may have some debris binding inside near the magnetic wheel. I'd try a new quality cable first.
  3. mj40's
    mj40's
    Usually caused from the cable binding in the housing. I usuall pull it out from the speedo end, wipe it down and re-install with powered graffite.
  4. Arthur1958
    Arthur1958
    I agree with 1950ChevySuburuban. The magnetic wheel is sticking to the drum inside the speedometer. It's probably just dirty. Take the speedometer apart and clean it; it won't be as difficult as you might expect.
  5. Mike51Merc
    Mike51Merc
    Frayed cable can bind and release causing jumping.
  6. Unkl Ian
    Unkl Ian
    Lube the shaft.
  7. j_johnson
    j_johnson
    from Iowa
    I had this same problem. I lubed it and it still did it. Then I loosened up the speedo side a little and it works great! Must have been a little too long of drive cable, but this wasnt the original cable either.
  8. hotcoupe
    hotcoupe
    if you dis***emble the drum you will HAVE to get the speedo re-calibraded.
  9. Arthur1958
    Arthur1958
    Your 1941 Pontiac speedometer is very simple. And it will work much better after you take it apart and clean it. Recalibration afterwards would be nice, but it’s not really a precision instrument anyway; it probably won’t be any less accurate than before.
