Technical Speedometer hookup 350 swap
Discussion in 'Traditional Hot Rods' started by PeggySue, Nov 11, 2020.
  1. PeggySue
    PeggySue
    Tried searching couldn't find .swapping to 350 turbo in 55 chevy. New turbo has blue speedometer gear inside ******. What all do I need to convert, does power glide housing fit 350? cable? which gear color if blue inside ******?
  2. pprather
    pprather
    I think your existing Speedo cable should work with TH350. Confirm?
    If that works, subsequent step will be to get it to read close to actual after it is running down the road.
    PeggySue likes this.
  3. PeggySue
    PeggySue
    What color gear would I use, the one in the powerglide?
  4. pprather
    pprather
    If the gears are the same other than color, I would use the PG one and see how it reads.
    gimpyshotrods likes this.
  5. PeggySue
    PeggySue
    ok thanks
  6. pprather
    pprather
    Report back here when you have drive car.
  7. gimpyshotrods
    gimpyshotrods
    I am not sure the gears were color coded in an Iron Powerglide.
    What truly matters is the tooth count on each of the two gears, and thus the ratio between them.
    What the speedometer measures is driveshaft RPM, so if you didn't change the rear end gears, or the rear tire diameter, that speed is the same, at any given speed, regardless of which model of transmission.
    The gear on the transmission output shaft is called the speedometer drive gear. The one that meshes with that, and that turns the speedometer cable is called the speedometer driven gear. Having the terms will help with the search.
    Counting the teeth on the driven gear is easy.
    On the drive gear, they are angled. You count the sides of those.
    Here is a good article: https://www.hotrod.com/articles/calibrate-gm-mechanical-speedometers/
    That shows an orange drive gear marked with yellow dots, where you count the teeth.
    A blue drive gear on a TH350 has 10-teeth.
    If you go to any search engine, and search the internet for: TH350 speedometer gears, you now know what to look for.
  8. gimpyshotrods
    gimpyshotrods
  9. e1956v
    e1956v
    Alliance Vendor
    The stem on the Powerglide speedometer driven gear is longer than the TH350 gear so you can not use it. Start with a 20 tooth driven gear, its in the middle of the gear range. Run the car on a measured mile and see how many 1/10's your turning in a mile. IE if you are turning 11/10's in a mile your 10% fast, the TH350 gear is 5% per tooth so if you went to a 22 tooth that would slow you down 10% and put you back at 10/10's in a mile.
    If its to far off you will need a gear ratio adapter to correct it( that is if you don't want to tear into the ****** to replace the drive gear)I can make you up a ratio adapter if needed just let me know how many 1/10's your turning in a mile.
  10. squirrel
    If the car is put together now, go for a drive and see how many percent the odometer is off, like he said.
    If the car is not put together yet and you can still easily get to the drive gear on the output shaft, count the teeth, do the calculation to figure out what driven gear you need to work with that, and your tire size and rear end gear ratio, as in the posts before the one above. Then get that gear, or if one is not available, you'll need to change both gears to get it to work.
  11. PeggySue
    PeggySue
    OK Probably in the spring, I'm northern MN , winter coming on cars up on blocks with ****** and rear end ***embly out. Getting ready to install ****** then rear end, plus have new wiring harness to put in. So my winter is planned.
  12. PeggySue
    PeggySue
    Thanks, will save this all this information . Found a kit for 350/ powerglide with bullet and gears 17,18,19,20,21,22
  13. PeggySue
    PeggySue
    Thanks will keep your contact, probably got ahead of myself car won't be on the road until spring being I'M northern mn, Wanted to do everything that I could before installing transmission
  14. PeggySue
    PeggySue
    The cars not put together as far as rear end and transmission, have a new 9" rear end 3.50 I'm installing along with the 350 transmission. Rear tires will stay the same.
  15. e1956v
    e1956v
    Alliance Vendor
    Avoid using the 17 tooth gear, it was mainly used on Pontiac's with a larger drive gear in the trans, if you use it with a standard TH350 drive gear it will strip and possibly damage your drive gear.
  16. PeggySue
    PeggySue
    After some thought I contacted the company I bought the new 350 transmission from. They asked my rear end gear ratio and tire size. Said a 23 teeth size was what I needed. I ordered it and will go from there, it will give me a starting point if its not right.
    pprather and e1956v like this.
