Hot Rods Speedometer redo
Discussion in 'The Hokey Ass Message Board' started by RottonRon, Apr 8, 2020.
  1. Looking for somebody to electrify a speedo ?? I can't run a cable . Thanks
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Rework a cable unit?
  3. Yes
  4. 57 HEAP
    57 HEAP
    Electrify a speedometer? Remove the speedometer cable drive. Cut the drive about 1 1/4 inches long and solder into speedometer drive. Attach the ignition positive to the shortened drive that is now soldered into it original location less the outer casing. Ground through the ch***is.
    Sorry, I couldn't help myself.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The easiest would be to find an electronic unit of equal sweep as cable unit. Then it's a matter of transferring guts. Sounds simple but understanding and patients is a must. There are gauge repair shops that do these types of mod's.
    olscrounger likes this.
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I think some of the well known guage manufacturers do that as well as standard guages. Depends on how stock you want the finished guages to look.
    Johnny Gee likes this.
  7. Bandit Billy
    Bandit Billy
    You can buy a GPS speedo to replace what you have. They work well.
