Technical Speedway 6" dropped axle
Discussion in 'Traditional Hot Rods' started by axel's40, Nov 27, 2017.
  1. axel's40
    axel's40
    Looking for someone who has installed/***embled Speedway 6" dropped axle kit. (duel leaf) Straight axle kit from them bolts together as kit , but their tech guy couldnt tell me how the dropped axle matches up to tie rods,spindles ,etc. You'd think/hope they have ***embled them in both configurations. Or any other reputable businesses that sell them? Going into 1940 plymouth business coupe
  2. Texas Webb
    Texas Webb
    No help,just confirm it's forged.
  3. axel's40
    axel's40
    thanks
  4. Fordors
    Fordors
    Not forged, it is a tube axle.
    To answer the OP if you bought the kit for Ford spindles for example then yes, ‘37-‘48 spindles will work. Stock spindles will require bending the steering arms to clear the 6” drop, or you could use bolt on aftermarket arms. Once the steering arms you decide on are on the car then and only then will you know how long your tie rod needs to be. The tech advisor has no idea about your particular combination of parts.
    BTW, the kit is “universal” (my favorite hot rod part word) and by that I mean it will adapt to many different frames. Be sure you weld the spring pads to the axle once you establish the correct location based on your frame width.
    dwollam and Texas Webb like this.
  5. axel's40
    axel's40
    thanks for the info
  6. jaw22w
    jaw22w
    from Indiana
    A 6" dropped axle can quickly get you into scrub line problems.
  7. 34Phil
    34Phil
    I did a 6" single leaf and figured scrub line would be OK with 165-80/15 but forgot about the hairpins which extend lower. In hindsight I should have done 4". With tie rod behind I am going to have to bend steering arms lower to clear frame by more than 1".
  8. axel's40
    axel's40
    This is why these forums are needed, probably saved me a lot of headaches with other rodders helping out.
    thanks
  9. axel's40
    axel's40
    Thanks, 4" might be a good plan for me
  10. long island vic
    long island vic
    WAC AXLES GO WITH THE BEST
  11. deathrowdave
    deathrowdave
    from NKy
    6 inch will bust the scrub line ! I used a 5 inch years ago it would clear . The owner burned up a nice set of front fenders , but damn it was loooow !
    Outback likes this.
  12. dirty old man
    dirty old man
    WTF is a "WAC" axle?????
  13. Hackerbilt
    Hackerbilt
    swade41 likes this.
  14. wuga
    wuga
    If they run one in the '38 Special', they must be well built, that thing does amazing wheel stands all day long.
    Warren
  15. dirty old man
    dirty old man
    I'll agree that those axles look well made, now that I've been to the site and looked around:cool: Didn't know about them, seems to be an old time like traditional hot rod shop. But I didn't see any mention of dropped axles, just straight g***er axles.
    Also, been reading for years here on HAMB and elsewhere that tube axles and split bones, or wishbones, are not a good idea with a tube axle. Only good with unsplit radius rods or 4 bar setup.:confused:
  16. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    School me here now, As I remember, a 40 Ply was one of the 1st cars to utilize a SLA control arm (independent front suspension) design along with tube shocks. 74631340-A48C-4254-9AD5-FAF13EF935CC.png
    (Pic front another HAMB post).
    So what exactly are you attempting to put under the Plymouth? Did ya just want to give it a different design like earlier quad spring cars?
    I don’t have any feedback on any thing that speedway sells suspension wise. If I’m doing a straight axle, it mostly would entail FoMoCo era specific components.
    If you’re seeking a dropped axle front end, it may take some engineering that the “Speedway Answer Man” May not have the experience to answer.
  17. krylon32
    krylon32
    from Nebraska
    If I was doing this in my shop and my customer demanded a tube axle I'd go to a forged 5 inch dropped tube from Magnum Products. Much safer.
    kidcampbell71 likes this.
  18. Luke stone
    Luke stone
    Sorry to drag an old thread up but I'm also interested in dropping my willys using a drop tube and parallel leafs. The 2 companies mentioned above magnum and WAC only seam to sell drop tubes for fords or transverse leafs or am I missing something? I've also been looking at the 6" speedway drop tube but I'm interested to no what problems getting into the scrub line will cause? I'm new to all this geometry and setup stuff but would like to get it right
    Thanks
    Luke
  19. Fordors
    Fordors
    Scrub line is described this way- if you were to stretch a line from the lowest part of a front rim to the lowest part of a rear rim would anything be below that line?
    In the event of a blow out could any of your front axle components, steering, exhaust, etc. come in contact with the roadway causing a potential catastrophic loss of control?
    But also, in the case of your Willys do either of the manufacturers mentioned have an axle in the width you would need? Check the C-C of the king pins on a Willys axle and then research the catalogs to see what they offer.
    Edit-I just went back and realized you mentioned WAC, I am sure he can make what you want, but consider the scrub first.
  20. Dean Lowe
    Dean Lowe
    [QUOTE Also, been reading for years here on HAMB and elsewhere that tube axles and split bones, or wishbones, are not a good idea with a tube axle. Only good with unsplit radius rods or 4 bar setup.:confused:[/QUOTE]
    Don't go there Dave. The blind will never see. :(
  21. Luke stone
    Luke stone
    Exactly what I thought it was ideally I want a 5" 6 is within the scrub line but not by much. The ones the above companies advertise have spring perch holes whereas the speedway one doesn't as I won't need them as I'll be running parallel leafs.
    I will contact WAC to see what they can do but I think I need a 48" as I'm sure my willys is 48 1/4
    Thanks for your help
    Luke
  22. mcsfabrication
    mcsfabrication
    I had a 6" dropped tube (from MAS, now defunct) in a Plymouth coupe. Had 6" wide front wheels with 165 x 15" tires. No scrub line issues. I did use Econoline spindles, and they may have brought the spindle a bit lower than early Ford, but not sure. It's been years.
  23. OLDSMAN
    OLDSMAN
    They make the axles to fit 37-48 Ford spindles or 49-54 Chevy spindles. If use original Ford spindles you will have to bend the steering arms for clearance reasons. Most people using Ford spindles use aftermarket spindles. These spindles have no steering arms on them but they also have steering arms available to fit the spindles.
  24. dirt t
    dirt t
    Don't forget when welding spring pads to axle allow for caster.
  25. krylon32
    krylon32
    from Nebraska
    I recently got a 5 inch dropped forged I beam axle (46 inch kingpin centers) from So-Cal and it is a very good quality product. I know Speedway used to have a man named Jelly making their tube axles in Wichita Ks and they were good quality but he died so who knows where they're coming from now?
  26. BCCHOPIT
    BCCHOPIT
  27. woodiewagon46
    woodiewagon46
    from New York
    What ever you decide, make sure it's USA made and not that offshore ****. The Chinese don't care if you live or die.
  28. Fordors
    Fordors
    They are not the only ones that are capable of manufacturing ****. I have a MAS, Minnesota Auto Specialties, dropped tube that I bought in the early ‘70’s and the king pin bosses vary by 3.5* side to side. Set one side at 7* and you get 10.5* on the other side.
    MAS didn’t care, no refunds, it’s been laying around all these years as a reminder, check everything and trust nobody.
  29. dirty old man
    dirty old man
    If I lived as close to Mn as you do, the day would come when they found that damn axle stuck thru their front window.
    Fordors likes this.
  30. tubman
    tubman
    M.A.S. made some crazy axles in the '60's though!:eek:
    a boner likes this.
