Hot Rods Speedway 9" rears
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Nov 10, 2024.
  1. panhead_pete
    panhead_pete
    Anyone got any 1st hand experience with the Speedway 9" rear ends?
  2. chevyfordman
    chevyfordman
    I've not had any luck with their Currie 9 inch third member. Pinion bearings went out after 5K miles, still in warranty so they replaced the bearings and the bearings went out after 5K again. I got a SpeedMaster third member next; so far so good.
    panhead_pete and olscrounger like this.
  3. 19Eddy30
    19Eddy30
    from VA
    Not on a compleat rear,
    A few years ago I ordered a 3rd member , according to the ad at that time they were built to order,
    When I received in a Red protective storage case ,was covered in rust , Not surfaced rust , Like sitting around for some time , Metal shaving inside 3rd member,
    After going round & round with pics emails, On dis***embling the bearings where heavy rusted ,races where pitted also ,I replaced & rebuilt 3rd member ,
    First time I had a problem with custmer service ,
    I have only had few issues since mid 80s with & miner ,
    Alway taken care of ,
    But 3rd member was a headache , cost me few hundred & 3 weeks of wasted time , I was lead that they where going to send Overhaul kit ..
    panhead_pete and Unkl Ian like this.
  4. krylon32
    krylon32
    from Nebraska
    I sold a few of their 9 inch centers with my ch***is with no problems but have started using Quick Performance.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    x2 QP
  6. Quick Performance here too.
    panhead_pete and Tow Truck Tom like this.
  7. snoc653
    snoc653
    from Iowa
    I've had very good luck with QP as well. The fact that they are fairly local (less than 2 hrs away) does give me that extra piece of mind when using them. If you go that route and they don't ship internationally, guessing since your profile says Japan, I'd be happy to help figure out how to get it to you. Just shoot me a PM if you need a hand.
  8. Kevin Ardinger
    Kevin Ardinger
    Does anyone build their own third members themselves anymore? It’s a whole lot cheaper. Find a good core ( plentiful) ring and pinion kit and bearings.
  9. 19Eddy30
    19Eddy30
    from VA
    seem like Op is in Japan , I would not think 9 inch not a common part/availability.
    Even here in Va Not to far from you ,
    Many , Many Junk yards/ salvage yards
    Crushed out alot of availability since
    2008 BS thinking , In Nokesville old junk yard cloesed up few years back, started s****ing Out , I knew one of s****ers , I punched 4 compleat 9 rears for $200 , all 4 where cut down & used , I should of purchased a few more .
    panhead_pete and Kevin Ardinger like this.
  10. squirrel
    very few of us.
    (Japan issue already mentioned by Eddy)
  11. continentaljohn
    continentaljohn
    I don’t have experience with speedway I use Moser and have good experiences.
    I use early bronco rearends right width and most have 3:54 gears. Plus the correct 5x5 1/2 bolt pattern with big brakes.. I wish you were closer as I have a few..
    panhead_pete likes this.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Yes, I do. But to do it right required that I made a few tools to make the job go easier.
    Spanner wrench for the carrier bearings
    Dial indicator for measuring case spread
    Spline ends with socket attachment for measuring limited slip break-away torque
    Carrier attachment for an engine stand or a vise
    Torque wrenches measuring foot-pounds and inch-punds
    Additionally, it helps to have an array of ***embly shims of varying thicknesses and a few crush collars and solid pinion bearing spacers ( depending on street or race) to make ***embly quicker.
    I ***ume nowadays you can look up how to ***emble a nine inch pig on YouTube. Knowing going in what it takes tool wise and proceedure wise will help you decide if its worth doing it yourself or farm it out to a pro. Even if you farm it out study the job and ask pertainent questions of the pro to be ***ured your pro knows how to do it right.
  13. 2devilles
    2devilles
    Another vote for Quick Performance. Very reasonable and built one at a time to order, I had a question and the guy called me on a Sunday to help me out. I won't go anywhere else after my experience on a couple different diffs from them.
  14. fordflambe
    fordflambe
    I had just begun shopping but decided to look here for inspiration and/or feedback regarding Speedway third members. Glad I looked! Thanks guys for sharing experiences, this will shape my decision in a good way!
  15. fastcar1953
    fastcar1953
    qp here also.
  16. DDDenny
    Hammer and chisel:eek: is more traditional!
    warbird1 and panhead_pete like this.
  17. deathrowdave
    deathrowdave
    from NKy
    I still do my own , the Dana 60’s in the Power Wagon were terrible . My new favorite is the Ford 8.8 . I have plenty of 9 in stuff laying around to keep me rolling for years
  18. lumpy 63
    lumpy 63
    I still build my own but my parts come from Quick Performance.
  19. RockyMtnWay
    RockyMtnWay
    Paid for one ten years ago.
    Only peeve was my housing ended up being 50.625 instead of the ascribed 51”.
    Unfortunately didn’t realize/measure until I fought with axle seal leak for a year.
    Finally got pissed and yanked the ***embly and double checked everything on the bench.
    Imagine how stupid I felt and how pissed I was.
    Re***embled and reinstalled after t******* axle shafts to correct lengths and bobs your uncle. Car has been the road now for nine years with zero year end issues.
    bchctybob, panhead_pete and SS327 like this.
  20. panhead_pete
    panhead_pete
    As always thanks all for the awesome feedback and kind offer @snoc653 !
    Yes sourcing one direct here in Japan is a PITA
    Will look at the Quick Performance.
    Once again thanks!
    bchctybob and RodStRace like this.
