Hot Rods Speedway Alternators
Discussion in 'The Hokey Ass Message Board' started by flatford39, Apr 15, 2017.
  1. flatford39
    flatford39
    Well after a lot of thought back and forth I have decided to go 12 Volt with my 31 Ford roadster with an 8BA in it. I am pretty certain the stock starter can handle it and since I am wiring from scratch I will change out all my bulbs. Not many in a 31 Model A so it will be relatively easy. What this means is that I need an alternator. Has anyone used the one wire GM chrome alternators that Speedway sells??? A plain alternator is just so ugly and I can't afford those new ones that are hidden in a generator case nor do I have the room for one with my dual carb set up.
    Any feedback will be appreciated. Thank you.
  2. denis4x4
    denis4x4
    from Colorado
    I've use a couple of them on my A powered cars with no issues over the past 8 or 10 years.
  3. Sheep Dip
    Sheep Dip
    from Central Ca
    Got one on the SBC in the 40........works like it's supposed to was!
  4. Hot Rod Grampa
    Hot Rod Grampa
    Have one in my 53 with original 6V starter. Going on 12 years no issues.
  5. wicarnut
    wicarnut
    I had them on 2 different HotRods, both for 7+ years, no problems, have another one on my Mercury 4 years, again no problems.
