Hot Rods Speedway bear claw latches?
Discussion in 'The Hokey Ass Message Board' started by rusty1, Dec 12, 2022.
  1. rusty1
    rusty1
    does anyone know if you can use your original outside door handles with the Speedway latches? thanks for any input.
  2. I see no reason why not if you can adapt the actuation
  3. Stu D Baker
    Stu D Baker
    from Illinois
    Bear claw latches typically are designed for heavy equipment cabs. That said, I'm sure it could be done on some vehicles, however, it's going to require some fabrication.
  4. Cosmo49
    Cosmo49
    Isn't there a HAMB guy selling bc latches right here?
    I got a great deal on the Trique latches and it was a top five improvement to my 1949 Chevy truck.
  5. theHIGHLANDER
    theHIGHLANDER
    Maybe I'm spoiled by the era and makes of cars I do, but I'd take the mega spring huge catch OG stuff over some janky import latch any day. Most catch by nearly ½" and I'll submit that if your doors flex that much there's a problem. Panera Bread has awesome bear claws tho...:rolleyes:
    Cosmo49 likes this.
  6. The Altman's are advertised as bolt in. The rest will require fabrication. I second the Trimark recommendation. Many of the early doors are very thin and the connection from the handle to the latch can be very interesting as well as either cutting an access panel in the door or having someone with really small hands to install the parts.
    Cosmo49 likes this.
  7. pprather
    pprather
    Cosmo49 likes this.
  8. Kiwi 4d
    Kiwi 4d
    Just be aware that some of the off brand mini bear claw latch are only rated to hold your lunch box closed. Sure the bigger ones require a slight bulge in an early door ,but only slight.
  9. rusty1
    rusty1
    thanks so far, working on a 50 Plymouth tudor,...mite be able to fix the original latches, haven't messed with them yet, no one makes a bear claw specific kit for this car.
  10. rockable
    rockable
  11. 38Chevy454
    38Chevy454
    This is me and my latches. If you want quality made in USA parts for good price contact me.
    You can use your stock handles if you want. It will require some fabrication to connect the handle motion to operate the latch release lever. With the window channel, the linkage may need to go down and then back up. My latches will work in any orientation, so whatever mounting gives easiest linkage is fine for the latch.
    You can also hook up the latch to the inner handle as well, with appropriate fabrication and connection.
    I have the installation kit parts as well if you need those. I keep all parts in stock and ready to ship when you determine what you want to order.
  12. gene-koning
    gene-koning
    Sam, does the 50 Plymouth have a drivers side key door lock? I'm not sure when Mopar added the driver side key lock. Without the outside key lock, the drivers door is locked from inside the car, and the p***enger side has the only outside door lock.
    Most aftermarket latch ***emblies do not have door locks.
    If you car does not have the outside lock, and you want to keep the ability to lock the door from inside, you will have to stay with an OEM latch. www.vintagepowerwagon.com has replacement door latches that have the functioning door lock. I believe the latches from the cars and trucks interchange up to the point of the outside key lock.
  13. pprather
    pprather
  14. X38
    X38
    Let's just say, Speedway don't make latches.
  15. rusty1
    rusty1
    thanks again, my car has outside door locks separate from the handles on both doors
