Hot Rods Speedway disc brake question
Discussion in 'The Hokey Ass Message Board' started by chronisterracing, May 18, 2016.
  1. chronisterracing
    chronisterracing
    from N.Il.
    this has probably been answered a few times but...... I have one of those speedway disc brake conversions for 37-41 ford spindles. My spindles are OEM off a 40 ford. my question is......after I put the adapter on, all new rotors and bearing and use speedway bearings my calipers are not centered..why?
    I'm thinking the bearing and seal adapter is machined wrong whether it be the filet or the seal part needs to be machined....
    Any help would be great!!!!!!
  2. dave plmley
    dave plmley
    Did you remove the tapered bearing that came in the rotors and replace them with new ones supplied in kit? That will seat your rotor back towards the spindle more. I just did one of the Speedway kits in my 41 Merc, great kit.
  3. Hotrodmyk
    Hotrodmyk
    Which kit number did you use??? Thanks.
  4. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    ^^^^^^^^^^^ YEP.
  5. chronisterracing
    chronisterracing
    from N.Il.
    Kit # 702-4475....yes I removed the bearing and race and used the ones supplied but only the inboard bearings were in the kit
    Sent from my SM-S890L using H.A.M.B. mobile app
  6. Chucky
    Chucky
    I'm not sure if this is your problem, but.....
    I had a kit from them years ago where the large "eared" bracket that held the caliper did not seat flush with the round back spindle. I had to clearance (grind) the large eared bracket's mating surface to get the two parts to fit flush with each other. It didn't take much grinding to make them fit. But, the small (1/8") gap at the mating surface extended out to the ears of the large bracket would have caused a serious mis-alignment of the rotor / caliper.
    Check that all 4 mounting bolts between the large eared bracket and the spindle are tight / there's no gap between the parts.
  7. chronisterracing
    chronisterracing
    from N.Il.
    grinding has been done, still not the fix.
  8. chronisterracing
    chronisterracing
    from N.Il.
    Just figured out the problem....even though the kit says 78-88 GM kit only the calipers are the metric style one must use the 73-77 Gm rotors
  9. mad mikey
    mad mikey
    Yep you got it! These kits do work very well , when you get them set up.
  10. fordor41
    fordor41
    I've had this brake set-up on my '41 for 18 yrs or so. Only problem I had was the bolts to mount the caliper bracket were too short. Also had to machine the spindle nut thinner to get the cotter pin installed. My instructions said to redrill the spindle. Not!
