Technical Speedway Flathead to C4 Trans Adaptor Kit
Discussion in 'The Hokey Ass Message Board' started by Flathead Dave, May 9, 2015.
  1. Flathead Dave
    Flathead Dave
    from So. Cal.
    Has anyone used the Speedway Flathead to C4 Trans Adaptor Kit? How thick is the adaptor? Did you like it? What do you think about it?
    I am thinking of buying the Speedway Flathead to C4 Trans Adaptor Kit but I am looking for some info on it so that I can do a mock up with measurements.
    I don't need info on the other brands only the Speedway kit.
  2. nmpontiac
    nmpontiac
    from Taos, NM
    Dave, I got the adapter kit for a c4 to flathead with a 53 Merc 4 1/8' stroker motor I bought. The one I have is the original mid 60s one made by another company that Speedway either bought or copied. There is a thin steel adapter plate and a thicker aluminum plate. I can send you the dimensions tomorrow morning if that will help.
  3. Blue One
    Blue One
    from Alberta
    You should run a search on here, there was a previous thread where the poor guy had nothing but trouble with the kit from speedway.
  4. Flathead Dave
    Flathead Dave
    from So. Cal.
  5. Flathead Dave
    Flathead Dave
    from So. Cal.
    Hi. The dimensions would be great. Thank you.
  6. nmpontiac
    nmpontiac
    from Taos, NM
    Dave, the block plate is .075 , the adapter is .380 - it was made by AFB Engineering in Monrovia. I think where people have trouble is with the starter, but the Speedway instructions are pretty thorough about making you've got the correct starter, drive gear, etc. DSCN1290.JPG
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
    Very cool info. Thanks a million! I was reading the instructions and they want you to mill a bit off of the block for the starter to fit. Not a hard detail to manage. Too easy.
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
    Got my Speedway adaptor kit today. It looks way too easy. I am going to install it tomorrow and see what it does.
  9. 19Eddy30
    19Eddy30
    from VA
    I have 1 in my 31 roadster ,51 flatty with c4 ,
    5 mnts of grinding , works great!!!
  10. paleot
    paleot
    from louisiana
    I have one in My 53, had to grind very little to make starter fit everything else fit spot on.
  11. Flathead Dave
    Flathead Dave
    from So. Cal.
    I put mine on today. I noticed that two of the mounting bolts are not flush and will not tighten any further. This gives me a fraction of an inch ( maybe a 1/32" gap) gap between the plate and the adaptor mount. I guess that I'll have grind the tip of the mounting bolts for them to snug properly.
