Speedway gasser axle ?
Discussion in 'The Hokey Ass Message Board' started by Bundy L, Apr 3, 2012.
  1. Bundy L
    Bundy L
    from Kentucky
    I have a speedway straight axle with the 49-54 chevy car spindles.This might be a stupid question but where do the steering stops go. I used search function but nothing came up. Any help would be appricated.
    Thanks
  2. Retro Jim
    Retro Jim
    I would guess that they would go on the inside and not the outside .
    Retro Jim
  3. axelnut1
    axelnut1
    I was just getting ready to ask the same question. I am running the same axle but with ford spindles. I am using the disc brake brackets that came with the straight axle kit. It looks like they use the brackets for a stop. When turned all the way the bracket hits the axle where the king pin boss is welded on. It still turns to sharp and I guess I will try to make a stop and use one of the bottom threaded holes for adjustability. I am using a Vega steering box with a crossover set-up. I sure hope someone has all ready been thru this, and maybe has a few pictures.
  4. rusty1
    rusty1
    ...stock 37 Chevy axle has a stop like this on the rear side...uses kingpin lock bolt.
  5. axelnut1
    axelnut1
    Thanks for the picture:). Speedway axle does not have the bolt, but it does give me another idea to look at. Thanks again.
  6. seb fontana
    seb fontana
    from ct
    What holds the king pin in the axle, a set screw?
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    If his speedway axle is like mine Then , yes , setscrew. I used an extra long set screw , locknut, then acorn nut to act as a stop , seems to work fine , been that way for 13 years & 35K miles !!
    dave
  8. axelnut1
    axelnut1
    Yes it has a set screw.
  9. Firecat7
    Firecat7
    yes typical speedway ....almost a good product. there is no engineered stop ...like "2old 2 fast" idea sounds good to me. Have at it:):eek:
  10. axelnut1
    axelnut1
    Thanks 2OLD2FAST, I will look at that fix to. I guess I was just thinking about it to much.
  11. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Most (all?) aftermarket tube axles are that way and always have been.
