Folks Of Interest Speedway headers
Discussion in 'The Hokey Ass Message Board' started by Boden, Mar 21, 2020.
  1. Boden
    Boden
    Does anyone run these flathead headers from speedway. Seem very affordable and the reviews aren’t bad. I want to buy a set for my 53 ford. Just was wondering if anyone runs em in general and what they think of em [​IMG]
  2. GordonC
    GordonC
    Kind off curious as to why you want to run headers? Is your flathead built up and needing extra exhaust flow? From everything I have seen/read there is little to be gained over the stock exhaust manifolds using a set of headers on a flattie. If it's simply because you like them and want to then have at it!
    Boden likes this.
  3. Flathead Dave
    Flathead Dave
    from So. Cal.
    I had some. They sounded very good. I ended up going with block huggers for my build.
    Make sure that they'll fit your build.
    Boden likes this.
  4. UNCLECHET
    UNCLECHET
    I put a set of "Red's Headers" on my 50 Ford 2 door sedan 20 years ago. The engine is stock but I wanted a dual exhaust. I was pleasantly surprised how much better it ran! Smoother and what felt like more power. I don't know about the Speedway headers for sure but I'll bet they'd help especially if you go with a dual exhaust system. What the hell, it can't hurt.
    Boden likes this.
  5. leon bee
    leon bee
    That's gonna clear your steering box?
  6. Boden
    Boden
    My motor is very built up. But also. I want to run dual exhaust. And the cost for manifolds is the same as these headers.
    anothercarguy and GordonC like this.
  7. Boden
    Boden
    We will find out. There’s no info about it on there
  8. tubman
    tubman
    Since you have a '53, these will probably fit. There can be problems with "shoeboxes" ('49-'51) and some earlier models; Even then, they can usually be made to fit.
    Here's something odd; I bought a set of cheap ($89.95) stainless headers off of eBay. The headers were fine, but the fasteners they sent with them were metric. How they could make decent headers and then send them out with metric fasteners is beyond me. Perhaps China is now casting their own flathead blocks?o_O
    Boden and GordonC like this.
  9. 1pickup
    1pickup
    Very tight to the steering box on my '39. Other than that, seem to be OK so far.
    Boden likes this.
  10. Boden
    Boden
    [emoji23]. I figured my 53 chasis is wider and a hair bigger than the shoebox cars. And it’s cheap enough to where if it doesn’t fit I won’t have a problem modifying jt
  11. vtx1800
    vtx1800
    I had Red's Headers on a 49 Ford and they were VERY close to the steering box:( Just a little tweaking could have easily added a half inch to the clearance. No idea why they don't. I was glad to see that car go down the road.
    Boden likes this.
  12. Model A Gomez
    Model A Gomez
    Used them on a 50 I had several years ago with no problems and I'm using the left one on my V8 A I'm building now. Flathead sounds a lot better with duals and gl*** packs, I used the Speedway Smithys on my 50, sounded good. Bought a set of Red's Headers for the A but it didn't clear the steering so borrowed a left header from a friend and it cleared so bought the set for the right header.
  13. Boden
    Boden
    Also. Has anyone run porter mufflers?
  14. denis4x4
    denis4x4
    from Colorado
    [QUOTE="
    Here's something odd; I bought a set of cheap ($89.95) stainless headers off of eBay. The headers were fine, but the fasteners they sent with them were metric. How they could make decent headers and then send them out with metric fasteners is beyond me. Perhaps China is now casting their own flathead blocks?o_O[/QUOTE]
    Bought A front license plate clamps and they came with metric fasteners as have several other aftermarket bolt on accessories.
    Boden likes this.
  15. Boden
    Boden
    I meant to say brochman mufflers
