Technical Speedway Pressure plate problems
Discussion in 'Traditional Hot Rods' started by Bbgun1936, Aug 24, 2025.
  1. Bbgun1936
    Bbgun1936
    I am working on a project that I nearly finished 8 years ago but life got busy and I am finally back to it. It had a rebuilt 8cm with kind of a mystery year 3 speed. At the time I bought a new 9" pressure plate and clutch from speedway and installed them. Trying to test drive it now I notice the throw out bearing can barely touch the fingers when it's fully pressed. You can see i have one photo fully pressed and one foot off clutch. What can I do? Do I need to pull the motor and trans? Is there a work around I can do? Thank you for your time!
  2. Several questions
    Did/have you adjusted the clutch linkage and free play?
    Was the flywheel resurfaced?
    Did you replace the throw out bearing and spring? (They look used.)
    Did you replace the throw out bearing fork?
  3. Bbgun1936
    Bbgun1936
    When I was tinkering with it today I disconnected the clutch linkage and used a wrench to get the full range of the fork, and that's what you see in the picture.
    The fork, bearing and spring were not replaced. Unfortunately I cannot remember if the flywheel was resurfaced.
  4. Bbgun1936
    Bbgun1936
    I will also note that this exact engine and trans combo was in the car when I picked it up.
  5. 38bill
    38bill
    from Minnesota
    Is the fork in the correct orientation and is it clocked correctly on the clutch shaft?
  6. Bbgun1936
    Bbgun1936
    Sorry I don't know, pretty much the whole transmission got pulled out of the car as is and put back in as is.
  7. 38bill
    38bill
    from Minnesota
    Can you take a photo looking back at the clutch fork
  8. krylon32
    krylon32
    from Nebraska
    2 possible problems. My customers call a lot with the type of problem your having which is normally an adjustment problem if everything was ***embled correctly. Another is the source of the parts.
  9. Bbgun1936
    Bbgun1936
    I will take one when I get off work tonight.
  10. Bbgun1936
    Bbgun1936
    Thank you, I was playing with the pressure plate finger adjuster and it did not seem like they could come forward any more. Would it likely be the fork could be adjusted forward? How close should the bearing be to the fingers with the clutch at rest?
  11. krylon32
    krylon32
    from Nebraska
    I have recommended 3/16 to a 1/4 with my T5 kits but stock Ford may be different?
  12. Bbgun1936
    Bbgun1936
  13. wuga
    wuga
    Are you running a long style of pressure plate like this? The fingers come out closer to the throw out bearing.
    Warren
    winduptoy likes this.
  14. Bbgun1936
    Bbgun1936
    Yeah, I still have the receipt 9" long style pressure plate part 91015651 from speedway
  15. Fordors
    Fordors
    If you are referring to the three bolts on the top of the clutch cover (the sheet metal stamping) those are not adjusters, they hold yokes that the fingers pivot on. You could loosen the yokes and place shims between the yoke and cover to lower the fingers or mill the yokes to raise the fingers but for sure milling the yokes will be a major operation requiring complete dis***embly of the pp.
    I think your clutch disc may be too thick for how that pp was built, a thinner disc would raise the fingers.
  16. alchemy
    alchemy
    That’s what I was thinking, too thick of disk.
