Speedway SBC Alternator High-Mount Bracket
Discussion in 'The Hokey Ass Message Board' started by TagMan, Aug 22, 2013.
  1. TagMan
    TagMan
    I can't use a low mount or "standard" mount bracket and, if this thing is built well, it'll work for me. Has anyone used this bracket and how did it work out for you ??
    Thanks,
    -Bob
  2. saltflats
    saltflats
    from Missouri
    Do thay have a tab going to the intake bolt for that saddle bracket?
    If not looks weak. Have you looked at Allen Grove (spelling) brackets ?
  3. have used several on other cars and i have one on my `28 tudor , works fine.....but the last few cars have had the one by So-Cal
  4. bjinx
    bjinx
    I used one on a '40 Ford pickup with a SBC motor, for the money worked great. Needed to shim at the intake bolt also.
  5. TagMan
    TagMan
    Thanks, guys. I'll check out Allen Grove & So Cal's offerings.
  6. krylon32
    krylon32
    from Nebraska
    3 words. Alan Grove Components!
  7. brandon
    brandon
    have one on my coupe....arm wouldn't work for my application...and you have to shim intake bolt to make it square...of course this is a universal piece , so you have to expect some of that .....look into bills hot rod brackets....used one of his a few years back , similar design , worked slick....
  8. Reds 29
    Reds 29
    I've had the speedway bracket on for 12 years, with no problem. I had to use shims in a couple places, but that was to be expected.
    Red
  9. aaggie
    aaggie
    I have one from Allen Grove that mounts in front of the p***enger side head and sits just above the water pump inlet. It bolts to the head and water pump, really out of the way of everything. Needs to be a long pump and won't work with the short pump. It was less than $40.
    OCIE likes this.
  10. Dooley
    Dooley
    from Buffalo NY
    i have the tallest one from alan grove, needed it to clear my RPM airgap...not trad but works for me..
    I have my old one that mounts to the p*** side with short pump if you want to try it....
  11. TagMan
    TagMan
    PM sent, Dooley.
  12. tfeverfred
    tfeverfred
    I used this one from Jegg's, but shortened and rethreaded the adjustment bracket to move it in close. Not sure of your set up. I actually thought about using that Speedway bracket, but the mounts looked like they would flex.
  13. TagMan
    TagMan
    I was also afraid of it flexing, which is why I posted here to see others experiences with them. Thanks for your input.
  14. uncle Dave
    uncle Dave
    I have one on my 38 coupe.....it looks nice but it is a cast Chinese piece of ****! Not very well desigined......I had to shim this adjust that.....after about 1 year it broke. Don't get me wrong ..I like and respect Speedway ..but sometimes.....!!! ud
  15. brandon
    brandon
    No flex...mines been on for 7 years and 3 motors....heck, ran once with vortecs and onlythewater pump bolt....:eek:
