speedway univ. radiator mounting
Discussion in 'The Hokey Ass Message Board' started by garagebuilt51, Jul 3, 2012.
  1. garagebuilt51
    garagebuilt51
    I just got my Chevy universal radiator from speedway for my 51 styleline. I need some ideas on mounting brackets. they come with no tabs or anything welded on. if anyone has pictures that would help.
  2. DrJ
    DrJ
    I would use the rubber "horseshoe" cradles used on "new" cars top, sides, and bottom
  3. Cerberus
    Cerberus
    Radiators should not be mounted fixed. The radiator needs to be able to move when the chassis flexes. If the radiator cannot move it will fail and leak. Henry had it dialed in with the support rods and spring mounted base in the 20's & 30's. Later, Ford used well nuts in the 60's.
