Hot Rods Speedweek 2024 Rons Hobby Shop Flathead Records Hot and Fast
Discussion in 'The Hokey Ass Message Board' started by ronnieroadster, Aug 11, 2024.
  1. ronnieroadster
    ronnieroadster
    Finally good salt at Speedweek this year after the two previous years of rain and slush.
    First run for our Rear Engine Modified Roadster running a supercharged stock block Ford flathead burning gasoline took place Saturday morning running against my current gas blown record of 205.744 I qualified at a speed of 215.473 MPH . The engine was not running perfectly experiencing a bit of a miss. Sunday mornings backup run was a complete failure the ignition issue being the cause the car only ran 187 so back to the pits to figure out what's going on.
    Checking timing we discovered what we thought was the problem. Put the car back in line and made another qualifying run the engine still had a miss fire but qualified over the record with a speed of 207.972. While we were working on the car in impound to get ready for Monday mornings backup run I decided to replace all of the electronic ignition parts out of the car. The ignition replacement was a simple dual point with condenser what I call good old 1980's ****og stuff. On the back up run on Monday morning the engine pulled strong the speed was 215.668 the new record established 211.830.
    Now it was my sons turn to run for the fuel record which the team set in 2021 with Jeff Arnett driving Jeff earned his Red hat in the car setting the fuel blown record {but still burning gas}at 206.249. On the qualifying run Monday afternoon with a density al***ude at 7770 feet the speed was 220.672 with an exit speed over 221 MPH oh I forgot to mention the temperature was 100 degrees outside every day. Tuesday mornings backup run the winds were blowing hard across the track. On the run the speed was 219.456 the new record established 218.240.
    Now it was time to change drivers this year a new driver on the salt Carly Moody. Carly has driven the car a number of times to speeds over 160 MPH in Maine at the LTA events previously but at Bonneville everyone is a rookie on their first runs ever on the salt. We worked to change the car so it would now be cl***ified as a gas rear engine modified roadster. To do this we removed the blower and in its place installed a two deuce intake I fabricated. This intake and carb set up as well as the cl*** change was going to be an experiment since we had never tried anything like this previously on the salt. To make a rookie run you can not exceed 150 MPH at mile 2 so Carly did her run perfectly running 137 MPH and deploying the chute as required.
    Carly was now qualified to run over 150 but not over 174 on her next p***. So back in line we go and this time Carly was now able to run the car to the third mile the current record was just over 140. On the run the speed was 157.616 back to impound. We now prepared the car for the backup run which Carly made latter in the afternoon. On this run the speed was 159.918. The temp out side on that run was 101.7 degrees with a density al***ude 7796 feet the now new record is 158.767.
    All three records were set with the car driving off the line under its own power no push starts. Speedweek 2024 was huge success for the entire team. Did I mention it was HOT!
    This stock block Ford flathead engine to date has run well over 60 miles on the salt many runs well over 200 MPH as they say in the movies she's a keeper Clark. :)
    Here's a great video of Carly's back up run. Turn up the volume sit back and enjoy the ride. :cool:
  2. pprather
    pprather
    Great job!
    Thanks for the detailed update.
    Congrats to the young drivers.
    Thanks, Ronnie.
    mad mikey and Dan from Oakland like this.
  3. Royalshifter
    Royalshifter
    Moderator
    That was awesome thank you.
    mad mikey, hrm2k and chryslerfan55 like this.
  4. DaveyJonez
    DaveyJonez
    from Houston
    Outstanding, Ronnie!!
    mad mikey and hrm2k like this.
  5. Budget36
    Budget36
    Great read, Ronnie.
    mad mikey likes this.
  6. krylon32
    krylon32
    from Nebraska
    Thanks. Great to see you giving a new generation a chance.
    mad mikey, hrm2k and brady1929 like this.
  7. chiro
    chiro
    Incredible.
    Andy
  8. Dave Gray
    Dave Gray
    Great job Ron. I was able to watch one of your runs on live-streaming.
    Dave Gray
  9. 05snopro440
    05snopro440
    I started following Carly Moody on Instagram/YouTube a couple years back when I came across her 32 build and it was a cool surprise that she was into Land Speed too. So I got to see her stories all week this past week. My family and I crewed for a streamliner at Speed Week 20+ years ago when I was a teenager, and it's awesome to see these young people driving at Bonneville and other land speed events.
    Thanks for sharing your update from the week!
    Spooky, mad mikey and Tim like this.
  10. AmishMike
    AmishMike
    Great, congratulations on great speed week. What was meaning of orange light? When turned off co**** banging & clanging increased - salt hitting car?
  11. hrm2k
    hrm2k
    Congratulations on the new cl*** Record !!! Your honey was posting all the action on FB so I got to see a bunch…..and you loaned out the car to someone else…..True Hot Rodder !!
  12. 05snopro440
    05snopro440
    The course and pit areas are graded, many areas on the side of the course are natural salt and a lot rougher and looser, so yes, what you heard was the equivalent of turning from a paved road to a gravel road.
  13. 37dodge
    37dodge
    So Cool! Great to hear that Flathead singing along at over 5K RPM.
    hrm2k and mad mikey like this.
  14. Stan Back
    Stan Back
    Best Bonneville video I've ever seen. I felt like I was right there. Looked like a pro driving. Congratulations on your many records, Ronnie.
    (Hmm, wonder if I could get just one more ride . . . )
  15. Hemi Joel
    Hemi Joel
    from Minnesota
    Congrats Ronnie Roadster on the 3 new records! How did you pick up MPH when your son drove? Amazing how strong it ran without the blower!
    We were trying to make it to Speed Week, but ran out of time.
  16. mad mikey
    mad mikey
    Thanks very much Ronnie, fantastic!
    hrm2k likes this.
  17. The37Kid
    The37Kid
    Congratulations! Hope that made up for the last two years with long two way drives and no runs.
    Bob
  18. Spooky
    Spooky
    WICKED KEWL!
  19. pbr40
    pbr40
    from NW Indiana
    Sounds like a very successful Bonneville go! Great sounding flatty.
  20. Mr48chev
    Great video, that was just flat fun to watch. It puts "come along for the ride" at a new level.
  21. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Epic, congrats to all 3 of yall! What a bad *** motor to take all 3 of yall to different records!
  22. wheeldog57
    wheeldog57
    Smashing records not just bumping them a little. Outstanding job by all!!
    If you want power from a flathead just listen to Ronnie. He's the king. I've had the pleasure on a couple of occasions
  23. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Congrats to Ronnie and the team. Been a Flathead follower and lover for 60 years plus. It is obvious u have put in the time and headaches to achieve the “unthinkable” of making the HENRY flathead possess more power and reliability than believed possible. Gr8 job by all connected with the program. There were others b4 your team, but I am here to say a “new king has been born”. Masterful job well done!!!! IMG_2200.jpeg IMG_1345.jpeg IMG_0723.jpeg IMG_0648.jpeg
  24. RodStRace
    RodStRace
    Like the others, I'd like to congratulate you on the records, thank you for the video and say that sure sounds healthy!
