Projects Spending my pennies and dimes on a 409
Discussion in 'The Hokey Ass Message Board' started by Taboo56Chevy, Nov 25, 2025.
  1. Taboo56Chevy
    Taboo56Chevy
    Figured I am far enough along in this project to start the thread on building the new 409 for our 61 Impala, its main thread can be found over in the off topic area as the wheels on it when we bought the car back we OT. Here is a direct link to it: https://www.jalopyjournal.com/forum/threads/2nd-time-around-1961-impala.1320589/
    That thread has a complete backstory and history of the car and its ties to the family.
    The big change this winter though is pulling out the 348 that is leaking out of every gasket and has a head with either a bad seal or guide, and swapping it with a dual quad 409.
    First thing was needing a block. Well to get that, my grandfather and I had to load up in the truck here in Aloha, Oregon and in 3 days drive to Sheridan, Wyoming and back home. This was back in early May last year.
    495377083_30257574293829603_769190108786183054_n.jpg 495187999_18456143122076672_739491659152687726_n.jpg 495096491_18456143131076672_6921827211214950590_n.jpg 495777596_18456143140076672_634218435646629210_n.jpg 495133586_18456143110076672_6601370544997523713_n.jpg
    The motor is a late 64 340hp. Pretty complete, only big missing items was the intake and the distributor. Luckily we have a couple spare W motor distributors.
  2. Taboo56Chevy
    Taboo56Chevy
    Got home and got a better look at the engine, this was just inspecting and going over all the casting numbers and really seeing what we have. Also in the pile of stuff we got was a 427 big block crank that had the mains turned down to do a stoker motor if we wanted to go that route. We decided not to, so gonna have that crank up for sale soon.
    495115749_30277546341832398_2495102569255846912_n.jpg 496096967_30277546835165682_627490655780384260_n.jpg 494698897_30277547098498989_5965800077761563380_n.jpg 494991248_30277546818499017_7477619811128933062_n.jpg 495450982_30277547505165615_6871013415364053169_n.jpg 495027457_30277545648499134_606424220620663263_n.jpg 495583874_30277546578499041_6825770238810058395_n.jpg 495087884_30277547161832316_420778236788446384_n.jpg 495153115_30277546375165728_5230894662665019347_n.jpg 495171852_30277546545165711_4978989899886491315_n.jpg 495622744_30277546015165764_7516258717174457542_n.jpg 495737291_30277545981832434_5888481844532528019_n.jpg 495132044_30277547411832291_2739154465708529265_n.jpg 494674820_30277545641832468_5643863379460348299_n.jpg
  3. Taboo56Chevy
    Taboo56Chevy
    Now with the big pieces home. Kind of put everything away as summer was hitting and got the other cars ready for the season. Did fall into a stash of high horsepower 409 stuff, the bigger 2.5" exhaust manifolds, another oil pan, set of old Jahns 20 over pistons, 11 inch alum bellhousing and the big thing a pair of 690 heads. These are the big hp units. Neat thing with them as well as they are super early 62 units so they have 61 casting dates and we early enough they were not pinned on the rocker studs like most 690s are.
    564747884_32840287412224932_8057976321553632031_n.jpg 566191927_32840282145558792_3196895029698734061_n.jpg 565694802_32840283175558689_6102113088614074144_n.jpg 565710279_32840283508891989_7917353843842610838_n.jpg 569372506_32840287968891543_6779521012419903651_n.jpg 566242227_32840283725558634_9074297691552904860_n.jpg 568408044_32840286875558319_5225274803150736923_n.jpg 565862622_32840284758891864_5259296292711097142_n.jpg
  4. Taboo56Chevy
    Taboo56Chevy
    During the summer at Goodguys in Puyallup met a fellow HAMBer and his Uncle with his sweet custom 56 Chevy that has a 409 in it. While chatting asked if he had any spare parts he wanted to maybe sell, but just flat out offered to let us have all the W stuff he had. So a few weeks later met him halfway, had breakfast, talked cars and racing for a bit and the loaded the car up with quite a big of W motor stuff. Super huge thanks for that. Its gonna help out quite a big with the build of this 409. Here is some of the stuff he p***ed along.
    566222245_32840284062225267_6534406552606966402_n.jpg 565708083_32840281652225508_3177396957482663299_n.jpg IMG_5459.jpeg IMG_5458.jpeg IMG_5457.jpeg IMG_5456.jpeg IMG_5455.jpeg IMG_5454.jpeg
  5. Taboo56Chevy
    Taboo56Chevy
    Forgot while in the process of this whole thing, also picked up a darn near NOS dual quad intake that is also a super early 62 unit as it again has a 1961 casting date. Kind of fun finding these early pieces that have 61 codes for the 61 Impala. Kind of helps with the theme for this engine is to make it look like Chevy actually did install a dual quad 409 in a 61 car.
    568372318_32840284332225240_3232149099175097575_n.jpg 565694536_32840285878891752_7731902931378713505_n.jpg 564628558_32840283068892033_1269206057347564266_n.jpg
    Also picked up a couple of 327 300hp AFB carbs pretty cheap to be able to convert them over to dual quad units for the manifold.
  6. Taboo56Chevy
    Taboo56Chevy
    Now fast forward to October and now it was time to load up the block and take it to the machine shop. One cylinder had a nasty scratch so ended up having to bore the block 30 over. Of the 2 std 409 cranks both were turned 10 already, one just needed a polish job, so went with that one. Got the new pistons swapped on the original rods after resizing and then had the whole thing balanced and then brought all the pieces home.
    565125335_32840285282225145_1786483790477543061_n.jpg 565079651_32840270472226626_8182058063833236870_n.jpg
    568693005_32840287948891545_2301793212104449425_n.jpg 571225817_32936007019319637_65754263645499067_n.jpg 572960803_18487510666076672_7197200061803183887_n.jpg 573009459_18487510600076672_2122838332366990129_n.jpg 568693005_32840287948891545_2301793212104449425_n.jpg 573916505_18487510693076672_8515383731896371320_n.jpg 573243036_18487510675076672_2352989963225232941_n.jpg
  7. Taboo56Chevy
    Taboo56Chevy
    While picking up the block, dropped the 690 heads off, along with new valves and guide plates to have them gone through.
    While the heads were at the machine shop, my grandfather and I got to work getting the rotating ***embly into the block.
    582504349_18490602115076672_7586840793936485263_n.jpg 581785412_18490602124076672_7929185471529873383_n.jpg
    582243572_18490602142076672_861432426275208842_n.jpg 581879487_18490602133076672_5150436388298139793_n.jpg 582217443_18490602151076672_1438899550882419133_n.jpg 581223355_18490602064076672_1854863251101245480_n.jpg
  8. krylon32
    krylon32
    from Nebraska
    Hunted & hunted for a 409 I could afford but had to settle for a 348 for a deuce highboy I built about 15 years ago. Looks like you have a good start.
  9. Taboo56Chevy
    Taboo56Chevy
    Got the heads back the machine shop next.
    581810243_18490602343076672_7443854111279731582_n.jpg 583198730_18490602322076672_2836447796357911953_n.jpg 583287004_18490602301076672_6555038951595402403_n.jpg
    Also took the cam core and lifters over to Oregon Cam Grinders to have it reground and the lifters resurface as they were all in good shape, no wiped lobe or lifter. Cam is roughly gonna be a L79 grind with a tighter LSA to give it a little more thump.
  10. Taboo56Chevy
    Taboo56Chevy
    yeah I hear you on that. We only have this 409 and the parts because we have scored some super deals along the way to make it possible. I had full intention this winter to just be pulling and fixing the 348 in the car currently.
  11. Taboo56Chevy
    Taboo56Chevy
    Currently still waiting on the camshaft so painted the tins and balancer yesterday, not gonna bolt the heads down until we can get the cam and timing chain in so can put the cover and pan on. Then roll it over and get the top end together.
  12. DDDenny
    Wow, quite a stash of "W" stuff, that intake is the real star of the show, and those chrome rocker covers, man gonna be a spectacular engine bay.
    You might PM @saltflats about the stroker crank, just a thought.
  13. Taboo56Chevy
    Taboo56Chevy
    Chrome covers are gonna be going on the 348 that will most likely end up in the 55 Chevy. For a correct 62 motor, I am stripping the 348 covers and painting them the proper silver the chrome didnt come out till 63. Still need to sell/trade my factory tri power air cleaner for a dual quad unit.
  14. saltflats
    saltflats
    from Missouri
    I run one of those in the race car now and have one fin another engine. Also have one that has the rod journals offset grounded to 2.1 still needs the mains and counter weights turned down.
  15. Taboo56Chevy
    Taboo56Chevy
    yeah this one just needs the front snout turned down if you want to run a stock timing cover or you get one of those special covers from show car and then run a big block balancer.
    Contemplated running it, but didnt want the spend more money on the motor as the 61 is just a cruiser where you occasionally put your foot in it. It is a true GM forged 427 crank.
  16. saltflats
    saltflats
    from Missouri
    Helped build a 348 into a 409 with a 427 crank and used one of those covers. Found the alinement pin holes were off a bit so had to do a work around so did have a front seal problem.
  17. Taboo56Chevy
    Taboo56Chevy
    Yeah I would think with this crank to just turn the snout down at this point. Honestly if I was gonna do a stroker motor, I would have just dropped the cash on a full kit from **** or Eagle so everything is matched and just have to machine the block to it.
  18. @Taboo56Chevy W blocks are my fav! Keep up the good work and I'll be following :)!!
  19. Bandit Billy
    Bandit Billy
    Dude, you are killing it once again! I have never owned one, but will always be one of my favorite engines. I can't wait to see it and hear it. My compliment to the chef.
  20. NoSurf
    NoSurf
    Very cool.
    Someday I'd like to build the 348 I have and drop it in my 57 wagon. Build it up like a super secret late 57 test mule....
  21. earlymopar
    earlymopar
    Looks great. Curious on the shop or shops you've used for the block and head work.
  22. Taboo56Chevy
    Taboo56Chevy
    Hutchins Performance in Beaverton/Portland did all the machine work on the block and heads.
  23. jaracer
    jaracer
    Been wondering about a good machine shop since Bearing Service closed.
    osage orange likes this.
  24. 1971BB427
    1971BB427
    from Oregon
    The two heads are different eras, one '62-'63 and one '63-'65. Are they the same chambers and ports and match each other?
  25. Taboo56Chevy
    Taboo56Chevy
    He does great work, has done the last handful of small blocks we have built. Only thing he doesn't do is turning cranks because he just doesn't have the machine or space to do it. He has to send those out, just had to change places as the shop in Portland closed recently.
    bchctybob, osage orange and Sharpone like this.
  26. Taboo56Chevy
    Taboo56Chevy
    the 409 blocks are all the same outside of it being a p***enger car or truck block. Heads will swap with no issues due to the heads being flat as a board, the combustion chamber is all in the block. You just need the matching intake manifold as the bolt pattern does change between the large heads and the small heads. Similar to the oval/rectangle port issue with a big block Chevy. You can bolt the big heads even on a 348 if you bore it out big enough to clear the intake valve.
    The only oddball head is the early 58 348's. The early 58 348s have different cooling p***ages and take a different spark plug and the block has matching water ports so they have to stay together. They revised that late 58 to how it would be the rest of the W motors life.
    The original 340hp 817 heads are basically slightly updated 1147 hi performance 348 heads. Same valve sizes as a 335/350hp 348 and uses the smaller bolt pattern. We are gonna end rebuilding those heads to swap onto the 348 coming out of the car to build more a 350hp 348.
  27. earlymopar
    earlymopar
    Can't wait to hear how everything works out. Glad to hear that you have one reliable shop doing both block and heads. Enjoy the "ride"!
    osage orange, mad mikey and Sharpone like this.
  28. Sharpone
    Sharpone
    Can’t wait to see finished product.
    Dan
  29. mad mikey
    mad mikey
    Fantastic! What is not to love about a snotty 409, Great engine and parts you have.
    porkshop, osage orange and Sharpone like this.
  30. Scott Younker
    Scott Younker
    Great thread! Best part about it is doing it with your Grandpa. I had a QB block, heads, DQ intake and crank, all date coded late 61 back in the early 90’s. My boss at the time had to let me go due to the business going down hill. Ended up selling it to him for $1000. It soon after was stolen out of his warehouse.
