Technical SPI epoxy primer
Discussion in 'The Hokey Ass Message Board' started by 1952henry, Sep 24, 2022.
  1. 1952henry
    1952henry
    First of all, I am not a painter. That said, I did my research and came to the conclusion that SPI semi gloss black epoxy is what I wanted for my 52 Ford frame. I followed the directions, and using an HF purple gun with regulator, commenced to painting the freshly blasted frame. I actually let mixed primer induce overnight for second coat. Apparently, the longer the inducing time, the better the UV resistance is. I could not be happier. Was easy to deal with, and came out quite well. Going to hit it later with a couple more coats once I rivet on some brackets and crossmembers I had removed. Also need to smooth some minor pits. Just wanted to share my experience.
    jimpopper, Chucky, Paulz and 3 others like this.
  2. oldiron 440
    oldiron 440
    I use PPG epoxy primers and sometimes I like the black with out paint it looks that good.
  3. SPI makes some great products.
    jimpopper likes this.
  4. jaw22w
    jaw22w
    from Indiana
    I have used SPI black epoxy primer on the las two cars. It is really great stuff and last I checked it was a lot cheaper than the big name competitors. The thing I really like about it is that it dries with a slight sheen. It works just like a guide coat for long board sanding.
