Technical Spindle identification
Discussion in 'The Hokey Ass Message Board' started by Grumps F1, Sep 14, 2021.
  1. Grumps F1
    Grumps F1
    I need help identifying this spindle. It's on my '51 Ford F1 and I am converting to disc. The spindle has an inner diameter of 1.251 instead of the stock 1.131. IMG_0561[1].JPG brakes.
  2. WiredSpider
    WiredSpider
    Looks like a Stock Spindle
    Carter and warhorseracing like this.
  3. That appears to be the driver's side F-1 spindle.
  4. Mr48chev
  5. i7083
    i7083
    Speedway Motors' website has spindle id pictures with measurements.
  6. ramblin dan
    ramblin dan
  7. Mr48chev
    Speedway and the others don't show F-1 or F-100 spindles. His is a stock F-1 drivers side spindle.
    X38 and Carter like this.
  8. gimpyshotrods
    gimpyshotrods
    1.1325 (reasonably 1.31, depending on the accuracy of the measuring tool) is the inner bearing inner diameter of the first-generation of the F-100 (1953-1956).
    Those look like this:
  9. gimpyshotrods
    gimpyshotrods
    The bump on the steering arm next to the tie rod end hole might be a steering stop. I am not sure. It may have been ground off on yours, as yours is otherwise modified.
    Either that, or your setup has the F-1 steering arm.
    In any case, I am pretty sure these are F-100 spindles, and you would need a disc brake kit for those.
  10. gimpyshotrods
    gimpyshotrods
    Take a look at these pictures from Nostalgia Sid:
    This is an F1 axle:
    Straight across horizontally in the middle. Shock eyelets. This is your axle.
    This is an F100 axle:
    Pan clearance dip in the middle. No shock eyelets.
    While the axles are different, they have the same kingpin boss height. The kingpin bore is bigger, by 0.0465" at 0.859" (versus 0.8125"), but that could have easily been reamed out.
  11. Grumps F1
    Grumps F1
    Thanks! You guys are the greatest!!
    After 75 years, one would think that I would know better than to work on someone else's project.
    You just never know what they had to drink, or smoke, before they came up with their bright ideas.
    Thanks again:)
  12. gimpyshotrods
    gimpyshotrods
    Happy to help!
