Technical Spindle king pin issues. Adapter question
Discussion in 'The Hokey Ass Message Board' started by SMH, Nov 17, 2018.
  1. F&J
    F&J
    Got it. I'd look for 40 style brakes or F100...locally, so you can see if the parts are ok, versus mail order on used parts.
    That early Ford stuff can still be found in my area, but maybe not where you are.
  2. SMH
    SMH
    That’s what I will do. F100 shouldn’t be to hard to find I would think.
    Thanks
  3. SMH
    SMH
    Here’s the way it sits right now waiting to figure this problem out.
    Sounds like I got lots of help and answers to my questions.
    Thanks
  4. lumpy 63
    lumpy 63
    You will have to grind a small notch in the top of the spindle for brake hose clearance, got em on my 29 roadster out stops several disc brake hot rods Iv'e driven.
    SMH likes this.
  5. lumpy 63
    lumpy 63
    Whoops... I didn't notice your rear discs...Might be some proportional issues there..
    X38 likes this.
  6. SMH
    SMH
    Yea not sure those are old hurst calipers. You cant really see the rear calipers so I think they are ok for now. I just really do not want front disc.
    I just asked around the F100 brakes maybe harder to find than I figured around here. If I cannot find used is there a economical complete kit you would recommend?
  7. lumpy 63
    lumpy 63
    Probably gonna get drawn and quartered for this....but maybe the So Cal fake Buick finned disc brake kit???
  8. SMH
    SMH
    Yea I saw that not very economical.
  9. X38
    X38
    Oh boy, once again it takes until post 28 to get the real truth of what we are dealing with. After all the guessing and supposing it would have been so easy to say "the car I have has a complete Lincoln front end, including brakes and I can't make a Ford spindle fit" right from the get go.
    I'm sorry my friend you are not the first and you won't be the last, but it does get tiresome.
    gimpyshotrods likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Must be all that hammering that's getting to you. :D
    X38 and gimpyshotrods like this.
  11. clem
    clem
    On a different note, and it may just be the camera angle, is there castor built into that front cross member ?
    mad mikey and X38 like this.
  12. gimpyshotrods
    gimpyshotrods
    Oh dear. M***ive discs on the rear, drums on the front.
    Holmes, you don't need an economical front drum setup. You need appropriate front DISC setup.
    If you don't want discs in the front, then you need drums in the rear, too.
    You don't get to make this choice. They are not called The Friendly Suggestions of Physics. They are laws. If you try to break them, at best, you will fail. At worst, you will die.
    Pist-n-Broke, mad mikey and X38 like this.
  13. deucemac
    deucemac
    I am running '50 F-2 backing plates which fit both '37-'41 spindles and '42-'48 spindles (which I am using). Shoes in 1 3/4 and 32 inch widths are available to match whatever drum you run. Much cheaper than the aftermarket Lincoln backing plates.
    SMH likes this.
  14. SMH
    SMH
    If I would have known what it was I would have said that. That's why I took the pics and measurements in first post. I did not know what I was dealing with. Trust me I am not trying to waste anyone's time. Anyway thanks.
    clem likes this.
  15. clem
    clem
    Don’t feel bad, I didn’t have a clue that it was a Lincoln front end either.
    While sometimes we may have knowledge in one area, sometimes we are still learning about some other facets of this hobby.
  16. alchemy
    alchemy
    If you want the cheapest F truck brakes that will pretty much bolt onto your new spindles and axle, look up Rich B's posts in the cl***ifieds. He is always listing rebuilt F-1 and F-100 front brake sets. The best deal you are gonna find.
    It will take a little swapping of bearings and seals, but I'm sure Rich can tell you which are required.
    Then, you can probably sell those Lincoln brakes and make back almost all the money you spent with Rich and those new spindles. Guys who know how to use them, and want the right old parts for their traditional car, are willing to pay a bit for them.
    Fordors likes this.
  17. AngleDrive
    AngleDrive
    from Florida
    I have purchased several sets from RichB. Excellent pieces.
  18. The square back 46 to 48 Ford spindles work much better than the round spindles on Lincoln backing plates.
  19. gimpyshotrods
    gimpyshotrods
    UM, HELLO, GUYS!
    He has DISCS on the rear!
    Please stop suggesting that he can fix his problems without addressing this stark, dangerous physics issue!
    No disc rear, drum front arrangement is appropriate here.
    If he wants to kill himself, don't teach him how to do it!
  20. 57 Fargo
    57 Fargo
    Gimpy is 100% right, the worst idea would be to have discs in the rear and drums in the front, guaranteed disaster!!
