Hot Rods spindle mount wheels
Discussion in 'The Hokey Ass Message Board' started by silent rick, Mar 30, 2020.
  1. silent rick
    silent rick
    how do you balance them? i suppose i can take them to a bike shop. any other ways to do it?
  2. I run them and have never balanced them. there is not much there to balance. never had a problem.
    maneri and mad mikey like this.
  3. Any shop with cup and cones should be able to balance it in a regular balancer.
    Iknow the newer snap was n machines and corgi ?? It’s a high end European tire machine have small diameter shaft and fit more wheels.
    what about a bubble balancer ?
  4. dana barlow
    dana barlow
    from Miami Fla.
    Stick-on Wt.
    Fordors likes this.
  5. rustydusty
    rustydusty
    How about "balancing beads"?
    Deuces, VANDENPLAS and silent rick like this.
  6. silent rick
    silent rick
    bearing is too small to fit over my bubble balancer. that's why i'm thinking bike shop.
    VANDENPLAS likes this.
  7. silent rick
    silent rick
    another idea i was thinking about
    Deuces and VANDENPLAS like this.
  8. silent rick
    silent rick
    planning on towel city's narrow front runners on a pair of hallcraft wire spindle mount wheels.
  9. Marty Strode
    Marty Strode
  10. silent rick
    silent rick
  11. mrhp
    mrhp
    from MICHIGAN
    I did not balance mine and have no shake at 133 mph.
    alchemy likes this.
  12. silent rick
    silent rick
    yeah but you don't go very far, just a 1/4 mile at a time. :)
    Deuces and clem like this.
  13. mrhp
    mrhp
    from MICHIGAN
    You forgot the shutdown, and the return road.:D
    Deuces likes this.
  14. silent rick
    silent rick
    think i'll start out with the static method. should the spindle be level? i think it would have to be, wouldn't it?
  15. pirate
    pirate
    from Alabama
    I have the beads in a car dolly I tow behind a motorhome. They seem to work well.
    Deuces likes this.
  16. Correct
    Had 'em on a tbucket years ago. Put a ****load of miles on them. Never needed to balance.
  17. fastcar1953
    fastcar1953
    You might try running them first. May not need balancing. My fronts are not balanced and do fine.
  18. Allmotor
    Allmotor
    Never balanced mine and no problems
  19. RICK R 44
    RICK R 44
    Back in the 60's there was a balancer that spun up the wheels on the car. They incorporated some sort of a strobe light system to indicate where to put the weights and how much weight You might be able to find one in an old shop that has been around since the 60's or 70's. Good luck
    MO54Frank likes this.
  20. 20191006_173327.jpg I race and street drive mine. I have done drag week for several years. I have never balanced them and they go almost 200 mph. You might be trying to solve a problem that's not there.
    fastcar1953 likes this.
  21. That's because your fronts rarely touch the ground except for right at the start!
