Technical Spindle question
Discussion in 'Traditional Hot Rods' started by Martinbuilt, Oct 22, 2025.
  1. Martinbuilt
    Martinbuilt
    This may be the most noob question ever, but it's been a year since i had time to look at these parts.
    I have a model a, with a '36 front axle. I bought a nice pair of round-back spindles, re-bushed and reamed to size.
    Today, i realized there is about 3/8" difference between the journals, compared to the model A and '36 spindles.
    Do i make spacers, or are these spindles not what i thought?
    2 7/8" between the upper and lower king pin journal.
    I can post photos in the am
  2. Fordors
    Fordors
    On Model A through ‘36 spindles the thrust bearing goes on the top of the spindle, the stock style king pins have a cup on top for the mechanical brake system and being a forging it will support the bearing and front weight of the car. ‘37-‘48 Ford king pins have a wider span and the thrust bearing goes under the axle.
    Deutscher likes this.
  3. Martinbuilt
    Martinbuilt
    Thanks.
    I completely forgot about the bearing placement.
    I need a nap.
    tricyclerob likes this.
