Spindle Question
Discussion in 'The Hokey Ass Message Board' started by FKNPOZER, Feb 18, 2005.
  1. FKNPOZER
    FKNPOZER
    from CALIFORNIA
    I've got front spindles tha t I bought from speedway.
    One of them is bent(long story).you cant tell until you try and put the pads on the caliper(make sense?).
    its very slight and I've even mounted and ran it.no vibration or wierd steering problems.
    now,the question.CAN IT BE REPAIRED,straightend etc...
    just curious.......thanx
  2. Unkl Ian
    Unkl Ian
    Did it get bent before,or after you bought it ? :confused:
    If it's a forging,it could be repaired.
    In theory.
  3. FKNPOZER
    FKNPOZER
    from CALIFORNIA
    it was bent after I bought it.Im being a petty little girl and dont want to buy another pair.
    yes they're forged not cast.
  4. DrJ
    DrJ
    And I thought I was a cheap *******.... :rolleyes:
    You are NEVER going to trust driving on that spindle. so.
    Buy a new one.
    It'll be cheaper than replacing the spindle, axle, oil pan, lamp post and your shorts and ****ies if it breaks.
  5. FKNPOZER
    FKNPOZER
    from CALIFORNIA
    not cheap" FRUGAL ":)
    hey doc, I got a new can of starting fluid for ya.
    seeing as we used yours up at the bbq.
  6. DrJ
    DrJ
    That's cool, they're cheap.
    Keep it in your rod for the next time you go out cruising with the guy with the inliner and no front brakes... or next time a half warmed up Y block needs a boost of happy juice.
    I use it mainly to start the lawn edger when the gas in it is stale. :rolleyes: ;) :cool:
