Technical Spindle snapped this weekend.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, May 5, 2025.
  1. 325w
    325w
    Did the lady have any good stuff to look at in the late husbands pile
  2. hotrodA
    hotrodA
    Wow! Very close to a really bad accident. Low speed failure, close by, you have parts and ability.
    You were very blessed!
  3. JMH24
    JMH24
    Your 1964 ElCamino did not originally have front disc brakes. Many of the common disk brake upgrades require either machining the upper boss of the drum brake spindle for the caliper bracket or changing to an aftermarket spindle made for the caliper bracket. I suspect the quality of these aftermarket spindles may not be as good as the OEM spindles. As others have said, that is a cl***ic fatigue crack, probably starting at a sharp notch, and probably influenced by poor metallurgy and heat treatment.
    Glad you didn’t have it break at highway speeds.
    alanp561 likes this.
