Technical Spindles for superbell axle
Discussion in 'Traditional Hot Rods' started by podslammed, Jan 22, 2014.
  1. podslammed
    podslammed
    I have a superbell front axle. I am wondering what spindles And brakes I could use.
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Anything from 1928 mechanicals through 1948 hydraulics, and any adaptation of brakes ever used on them (the list is HUGE)
  3. 56shoebox
    56shoebox
    Mine has 40 Ford spindles with drum brakes. (I ***ume 40s also. They were on the car when I bought it. I hope the pads never wear out. I would hate to have to find out what they are for replacement sake.)
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Most folks use either the 37-41 spindles with round flange marked 78- or the 42-48 spindles with square flange marked 21A-. As above there are many different brake setups can be used on these two spindle sets, wjereas there are only a couple for the 28-31, 32-34 and 35-36 sets.
  5. gimpyshotrods
    gimpyshotrods
    Just post a picture of the backing plates, and someone here will tell you, within a few minutes, probably with a link to where you can get the shoes.
  6. podslammed
    podslammed
    I am looking to rundisc brakes. Would these spindles still work for that?
  7. Texas Webb
    Texas Webb
  8. banginona40
    banginona40
    I'm using early '60's Volvo disc brakes on my Super Bell Axle.
  9. alchemy
    alchemy
    If your axle is an old production, be aware that they did make them to fit Chevy spindles as well. Measure the height of the kingpin boss and the dia of the kingpin and post them here. Somebody will have the correct numbers to compare.
  10. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    If the axle is for Ford spindles, you want 1937-1948 Ford spindles and just about every hot rod company makes discs for them.
