spindles
Discussion in 'The Hokey Ass Message Board' started by fasteddie, May 14, 2011.
  1. fasteddie
    fasteddie
    from mass.
    why does everyone use 37-48 ford front spindles? whats wrong with 32-34 spindles?
  2. The37Kid
    The37Kid
    I think the cross steer and juice brake backing plate bolt holes are the main reason.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    The earlier spindle are just fine as spindles but almost nothing except the hydraulic brake adaptor kits to mount 39-48 brakes on them is available.
    The stub axle of the early spindles is longer than the 37-41 or 42-48 spindles and the backingplate flanges are smaller and use smaller fasteners.
  4. fasteddie
    fasteddie
    from mass.
    i am runing disc so backing plate are not a problem.
  5. juice!... as above mentioned the steering arm bolt holes as well
  6. Harms Way
    Harms Way
    The configuration with the thrust bearing works better after 37' (or so the story goes)
  7. fasteddie
    fasteddie
    from mass.
    thanks just wanted to know i have both and 32 lood good with factory steering arms.
  8. Since you said you are going to run disc brakes, you will find that you will probably have fabricate your own caliper brackets and figure out the bearing adapters. The common kits are made for '37-'48 spindles which have a different bolt pattern and
    register circle.
