split bone with tie rod ends
Discussion in 'The Hokey Ass Message Board' started by keystone30A, Dec 13, 2012.
  1. keystone30A
    keystone30A
    When using a split wishbone with tie rod ends (model a) how do you guys break the taper to adjust the front end without damaging the finish(paint, powder coat, etc.) I plan on having my frame powdercoated when finished with everything.
    and does anyone sell wheel well patch panels that include the inner wheel well lip? mine have been butchered by a previous owner.
  2. Ghost of ElMirage
    Ghost of ElMirage
    What do you mean by "break the taper"?
  3. HOTRODPRIMER
    HOTRODPRIMER
    Same thing I was thinking.
    Are you planning on welding in a bung?,,if so you can use a nut on the tie rod to adjust it. HRP
  4. 117harv
    117harv
    Pickle fork?
  5. keystone30A
    keystone30A
    how do you remove the tie rod end from the frame mount? if its like modern tie rod ends and ball joints when they are seated in the steering knuckle you have to hit the knuckle with a hammer to "break the taper" or use a pickle fork which usually destroys the grease boot.
  6. racemad55
    racemad55
    Mock it up for caster before paint.
  7. HOTRODPRIMER
    HOTRODPRIMER
    I guess,I misunderstood what hes asking,,yeah,a pickle fork works well. HRP
  8. Tudor
    Tudor
    from GA
    he said bung and pickle fork
  9. TurboX2
    TurboX2
    No matter what tool you use it will be tough not to damage the finish. You will have to be very very careful.
  10. 117harv
    117harv
    Painted bones, do your adjustments, tape off the ends and paint. If powder coated, when you get them back you don't have to fully seat the tie rod ends into the taper to get everything adjusted. Once adjusted, tighten the nuts down and seat the taper.
  11. keystone30A
    keystone30A
    makes sense. thanks
  12. el Scotto
    el Scotto
    from Tracy, CA
    I have a tie rod removal tool that is great! I've used on muscle Mopars, hot rods, even my 1956 Chevy! :D
    Well worth the $10-$12 I paid for it at O'Reillys! ;)
  13. Rem
    Rem
    Make sure there's no paint or powder coat in the tapered holes before final ***embly.
  14. sunbeam
    sunbeam
    What Alinement setting are you going to adjust with the wishbones after you get the axle square?
