Technical Split bones w/60hp tubular axle
Discussion in 'Traditional Hot Rods' started by dapirate, Mar 20, 2014.
  1. dapirate
    dapirate
    from Alpharetta
    Hey guys,
    In browsing the forum, it appears there may be issues with running this setup, which is exactly what I have.
    I have a light weight fenderless roadster and thinking I'm ok but just not sure?
    I've had my 29 for almost a year and it rides and drives like a dream. I would never think it was built wrong. also, I have a leaf in the front not the coil overs.
    Is there ever an instance where this setup is ok?
    Do I need to change anything?
    If I do, what are my options
    Thanks
    :confused:
  2. Texas Webb
    Texas Webb
    Well a tube axel does not twist like an I-beam and a 4 bar setup is usually
    recommended.There will be other knowledgeable answers.
  3. snaptwo
    snaptwo
    We ran a genie Ford tube under a '57 Corvette g***er using batwings and split bars. Worked just fine in a straight line situation .
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    We've all seen 37-40 tube axles used wth split bones, four-bars, hairpins, spring forward, spring behind, spring on top, under any number open and closed cars with and without fenders so I wouldn't sweat it too much.
  5. dapirate
    dapirate
    from Alpharetta
    Oh ok, cool
    so it sounds like 4 bars is the best setup, but its not crucial to change it immediately if I want to change it.
  6. Rob Paul
    Rob Paul
    Split bones all the way. That's a bad *** axle. Don't take away from with a lame aftermarket 4-bar. That axle is not like your standard t-bucket aftermarket tube axle. Yours is forged.
  7. dapirate
    dapirate
    from Alpharetta
    Thanks I feel a lot better!!!
  8. fortynut
    fortynut
    I bought one of these axles for a more traditional '25 T Roadster I'm scrounging parts to build --- as a track roadster, similar to but not exactly like the one Duffy Livingston raced in the sixties. I have pondered the same question, because a set of bones came in the deal and using them would make it easier. I store a lot of parts by hanging them under a loft in my shop. I tied a loop through the kingpin tube on one end and the axle hangs straight up and down. While adding other parts I bumped the axle; it rang like a bell. A very beautiful sound! The steel is of very high quality. Then, I remembered the Liberty Bell. Something hard enough to ring will not endure twisting stresses very well. It was not designed for that. In all probability a crack will result, how bad one can only speculate. This outcome cannot be good. Bravado aside, Murphys Law applies: It is not if, but when something happens. I'm going to use a four-bar set up, and like the Eliminator I'll use tie rod ends, where applicable. Personally, if I drove a rod built with a V8-60 axle and split wishbones, I'd change the axle, or replace the bones with bars. Other opinions may vary based on personal bias, and experience. Carl
  9. dapirate
    dapirate
    from Alpharetta
    ok lets do this, has this 60hp tubular axle axle ever broken on anyone with split bones?
  10. turdytoo
    turdytoo
    Take a look at the Ivo "T".
  11. If i remember correctly Brian B*** used a tube axle on one of the cars he built, i'd have a look at the threads of his builds and find which one used the tube axle and go from there.
  12. 32 gasser coupe
    32 gasser coupe
    Harry Luzader's National record holder 32 Ford D/G***er fron the 60's ran split bones w/60hp 1937 tubular axle. Leaving the line he'd pull the front wheels up through 1st gear and bounce them up again in 2nd. That axle withstood that punishment so I think you will be OK,
  13. The split bones work just fine on a tube axle. They only don't work in someone's theoretical opinion.
  14. thunderbirdesq
    thunderbirdesq
    Ivo's T used a four bar.
  15. dapirate
    dapirate
    from Alpharetta
    I definitely don't think I'll be doing wheelies with my 305, lol :p
  16. Andy
    Andy
    My friend had a tube axle and split bones. He would shear the bottom off the perch bolts if he got it twisted like going up an incline at an angle. He used to carry a spare perch. The car drove fine with it sheared. It just freed up the axle so it could work with the road. It would have been a problem if he sheared the top and the wishbone became free.
  17. Harms Way
    Harms Way
    Just like "All the failed 35-36 Rear Wishbones" Stories that I have herd, But nobody can prove,.... I have only herd of a failure once that was do***ent-able about failed perch pins with split bones and a tube axle... And it was using cheap repo cast perch pins.....
    If you guys are thinking your "hairpins" are flexing to compensate for the twist, or lack of twist in a axle... I would be worried about the stress on your hairpins if this same pressure can snap a perch pin.....
    I have been told about the theory of Hairpins with Tubes and Wishbones with I Beams Only ! for decades,.... Well somebody needs to tell these guys how badly they screwed up.....
    Split bones with a tube
    Beam with hairpins,....
    And again Split bones with a V8-60 Axle,..... Frank put a ton of miles on this car in all kinds of situations for almost 50 years and NEVER had a problem with the pins.
  18. Harm,
    Thanks man.
  19. turdytoo
    turdytoo
    I believe if you will check it out you will find Ivo's had hair pins
  20. steel rebel
    steel rebel
    What ****** said.
    Twenty five years and probably as many thousand miles and no problem. You have to ask yourself how much your front suspension will travel. If it is just a few inches as mine does the rod ends will compensate for that. If it is a lot more you need to do something else.
  21. Harms Way
    Harms Way
    OK,... and to add fuel to the fire,..:D
    It looks like you have the very early and cool PSI Hairpins !,.... Now most of these were built with solid rods between the cast yoke,... and the female clevis. Most engineers will tell you that a solid rod is considerably weaker than "DOM Tubing" (Which almost all other Hairpins are made out of ) And these old PSI Hairpins are structurally weak and dangerous !
    And here you are 25 years later still riding around on them..... Sometimes were just to darn smart for out own good.
  22. lrs30
    lrs30
    from Kentucky
    My buddy and hot rod guru "Whitney" (Richcraft.Spl) runs a 60 and split bones on his roadster and runs it hard, I've seen him split the red sea, conquer everest, slappy grind it, push off fuel cars, and vintage sprints, hitting well over 100 on the back roads to many dirt track races during Indy speed weeks, busting great times at the strip and all with 7 asian ******s in the trunk all while not dropping a drip of brown liquor while doing it! ok it was with 5 ******s and 3 where dead, but point being, I'd say yhea it can be done! If your afraid send it to me and I will run it!
  23. Kevin Lee
    Kevin Lee
    Super Moderator
    This is so great. Are the axles worn through yet or does he use copers? :D
  24. lrs30
    lrs30
    from Kentucky
    Nah he is hard core, not plastic or Z-rollers here, it's 169 built to grind style ;)!
  25. steel rebel
    steel rebel
    Good eye. You are correct they are early PSI. I did though grind off the initials before having them chromed.
    I guess ignorance is/was bliss. Thanks I think. I'll keep running them though. If you want/need the most safety out there don't drive a T bucket, get a Volvo.
  26. ProEnfo
    ProEnfo
    from Motown
    I think not... :rolleyes: it was a four bar.
      115.6 KB
      152.4 KB
  27. steel rebel
    steel rebel
    No he didn't use front hairpins he was pretty true to his copy of Grabowski's T. Four bar suspension and all.
  28. turdytoo
    turdytoo
    My bad. There is a clone/tribute car with a aftermarket tube axle (not '37) and hair pins I had been studying. I stand corrected.
