Split bones with a tube axle?
Discussion in 'The Hokey Ass Message Board' started by raven, Jan 6, 2014.
  1. raven
    raven
    Is this ok or am I asking for trouble?
    r
  2. This question will create an arguement all day long, so Im staying neutral (even though I have my oppinions). Just do a search on how I beams twist and tubes do not, and you can read all the fights from the beginning of the HAMB.
    :cool:
  3. I don't think I would,,the split bones will articulate and try to twist the tube axle..tube axles will not flex.
    Not conjecture,actual real world experience...I built a 1939 Ford with a Superbell tube axle and split bones not giving thought to any eventual problem but a few years after I built the car I hit a pretty serious pot hole and snapped a spring perch even with the top of the axle boss.
    Hard lesson learned for me.HRP
  4. raven
    raven
    Thanks, HRP. That info was stuck in the deep recesses of my mind and couldn't find the light of day, it's been so long..
    I guess I should have asked before I bought the bones...
    r
  5. Hnstray
    Hnstray
    from Quincy, IL
    or the tube axle........:D
  6. aonemarine
    aonemarine
    from Delaware
    Better off running hair pins on tube axles....
  7. raven
    raven
    Ha.
    I've had the chrome tube axle for a number of years waiting for me to use it.
    The bones just came in the mail a couple of days ago and are still in the unopened box next to the dinning room table, so the axle wins out over my stupidity.
    r
  8. Hair Pins or 4 bar (not traditional but they work). HRP
  9. raven
    raven
    I have some short hairpins I might use. Just have to get the batwings and clevises.
    Since I have fenders for this coupe, a 4-bar would be covered anyway.
    r
  10. aonemarine
    aonemarine
    from Delaware
    Didn't they have hair pins pre 1960? Why aren't they traditional??
    This traditional stuff is very confusing.....
  11. TANNERGANG
    TANNERGANG
    from alabama
    Ohhhhhh Noooooooo.....if it ain't TRADITIONAL.......don't dare use them....I took steelies off my '32 and put a set of Salt Flats on it and now it is considered a Street Rod and my ad was deleted from the Classified section for sale......... we dare not!!!!!......hairpins and 4 bar would make it a Street Rod.
  12. Hnstray
    Hnstray
    from Quincy, IL
    If by "hairpins" you mean a three point attachment, two at the front axle and one at the back to the frame, they are functionally no different than split bones. They may look better or different, but still impose the same undesired forces on the axle.
    Perhaps you mean "4 bar", which offers some relief from the twisting force of bones but does move in an arc and the axle will move fore and aft a very small, likely negligible amount. Other than an original wishbone configuration, I believe the 4 bar offers the best solution to the tube axle.
  13. scrap metal 48
    scrap metal 48
    I'm still looking for reasons it's OK to run tube axle with bones, but haven't found the definitive answer yet...
  14. ^^^^ not touching that with my non traditional 10' pole :cool:
  15. Sure they did & they are traditional,,the 4 bar isn't what we consider traditional. HRP
  16. aonemarine
    aonemarine
    from Delaware
    I have to disagree, the hair pins let the top and bottom bars twist apart from each other where a single bone has to twist its length. Far less forces on the hair pin.
  17. tfeverfred
    tfeverfred
    Hair pins are relatively cheap. Keep or swap the bones. I'm running hair pins with my "I" beam, but wish I had used bones.
  18. V8 Bob
    V8 Bob
    The 4-bar design has been around for many years, but it took P&J in the '70s to make it work properly. I've got a a 1951 hot rod book with a pictured 4-bar setup, and bet the concept was initiated earlier. Whats not traditional about it? :)
  19. Hnstray
    Hnstray
    from Quincy, IL
    I understand the point you wish to make, but it doesn't address the issue.
    Twisting of the bones or hairpins IS NOT the forces that are problematic. It is the fact that bones and/or hairpins tend to twist the axle itself as the wheels rise and fall over irregular surfaces. The I beam axle will twist rather easily whereas the tube axle will not. That difference induces loads on the axle and all bones/hairpin mounts and attach points.
  20. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    We ????
  21. tfeverfred
    tfeverfred
  22. 95%+ of t buckets probably, use tubes and radius rods (hairpins),,,, Im surprised the highways arent just littered with all of the front ends falling apart. :rolleyes:
  23. Thats CLASSIC :D
  24. 117harv
    117harv
    Yep, saw lots of sprint cars driving around town when I was a kid.
  25. aonemarine
    aonemarine
    from Delaware
    Where is a auto Cad super geek when you need one? It would be very interesting to see a computer model of all the different arrangements and the forces that are implied by them.
    Until someone models the suspension all comments can be considered nothing more than speculation. I'd bet your all in for a real eye opener....and I bet most of the twist and flex is not in the axle, but elsewhere.
  26. Hnstray
    Hnstray
    from Quincy, IL
    You are correct, examples of incorrect construction abound.
    If the standard is "whatever you can get away with for some undetermined amount of time", vs applying relatively simple, and well known, engineering principles to make your build sound in all respects....then, by all means...blunder on. Just don't see how one can be so proud of it.
  27. I snapped both spring perches (at different times) with a flat dropped axle right where the nut meets the bottom of the axle. Pretty sure it was from hitting the small incline in my driveway to fast/hard as I've never hit a big chuck hole etc.?
  28. scrap metal 48
    scrap metal 48
    How does the Chemical City Coupe get away with a chromed V8 60 axle and split to the frame wishbones?? I know it's a torsion set up but that really wouldn't make a difference, or would it.. I could not find any reason in his build thread.. I love that coupe BTW...
  29. I never said its RIGHT on an engineering aspect, but please explain to these fine folk why they are not falling apart all over the place. Tube axles have been used for DECADES with bones and pins, with VERY few failures. Why is that?
