Technical Split wish bones
Discussion in 'Traditional Hot Rods' started by Wildbill29tudor, Jan 3, 2014.
  1. Pewsplace
    Pewsplace
    Splitting wishbones is not rocket science. When in doubt, study, then install as suggested.
  2. saltflats
    saltflats
    from Missouri
    So the caster is set in the spring mount cross member then you can make small adjustments with the wishbone mounts. And the wishbone mount height is more of what looks wright. Am I thinking correct or just full of ****?
  3. evintho
    evintho
    Bingo!
  4. gimpyshotrods
    gimpyshotrods
    Moving the wishbone mounts up or down changes the roll center of the vehicle, and will affect handling.
    Jet96 likes this.
  5. trollst
    trollst
    All these varying opinions just scare the **** out of new guys, my opinion is, sit down right here on the net and read all you can, come to a plan that works for you and get on with it. Fact is.....there isn't anyone here, me included, who hasn't done stuff like this for the very first time, and wasn't full of self doubt as to whether it is right. All of us learn by example, reading and doing. Good luck, education is power.
  6. JLB3
    JLB3
    When the split wishbones are mounted out on the frame rails, does that not cause the tire to rub at full lock?
  7. scrap metal 48
    scrap metal 48
    Tire rub depends on how wide apart the perch bolt holes are.. If using an aftermarket axle you'll have no problem.. Some stock axles(like a 40 Ford) you will have tire rub...
  8. sunbeam
    sunbeam
    Does any one make flat top axle perch bolt that has an offset head that would allow for caster adjustment. Some what like camber bolt for struts.
  9. crminal
    crminal
    Some good information about that here; http://www.jalopyjournal.com/forum/showthread.php?t=824962
    Different length bones, different steering setups, concerns about turning radius will all play into the bone mounting question. If you are building standard fare, it is easier. If you are building outside the box, learn the basics, listen to people who have been there, done that. The link above is a great example.;)
  10. falcongeorge
    falcongeorge
    from BC
    Hadn't considered this before, thanks VERY much for posting it. Down raises it?
  11. flthd31
    flthd31
    If your spring is mounted in a cross member that didn't have enough caster when the frame was built, these perch pins are available to allow more caster without putting the spring in a bind. Not too traditional, but they work well.
  12. RICH B
    RICH B
    Give you an idea, Model A axle (same perch centers up to '36) and '40 bones with the rear mount on the inner edge of an A frame. 5:60 x 15 on an early F-100 rim. Less than a quarters diameter clearance to the bones with the spindle against the stock steering stop.
  13. WillieRides57
    WillieRides57
    A lot of good info here. I'm working on my 1st Model "A" and plan on splitting the 'bones and making my own rear brackets. Built quite a few dirt cars in my time so 5-7 degrees seems reasonable. More initial caster = more difficult they are to turn so I'll stay closer to 4 1/2-5 degrees.
  14. mgermca
    mgermca
  15. k32t
    k32t
    from Hog town
    my 32
  16. 19Fordy
    19Fordy
  17. 383deuce
    383deuce
    well writen my friend
  18. ago
    ago
    from pgh. pa.
    Unsplit wishbones will allow the body to roll more and have a more flexible suspension. Splitting the bones will bind and stiffen the roll (like anti roll bar).
    Ago
  19. 19Fordy
    19Fordy
    True, but I believe there is a limit as to the amount of strain that split wishbones can sustain over time
    without fracturing, especially if they are spread wider and wider -for instance out to the side rails.
  20. HellsHotRods
    HellsHotRods
    It's amazing how everyone thinks they are an instant mechanical engineer . As if what Henry Ford did was all wrong. Henry Ford had the X configuration suspension all figured out, nothing could be better.
    But today everyone thinks that wishbones need to be split, torque tubes aren't necessary, anti-chatter rods are useless, etc etc
    The only reason to split a wishbone is to make room for an alternative engine. Your mounts will be determined after you set the axle at 7 deg caster.
    dmar836 likes this.
  21. THATS A NICE CH***IS UNDER THAT TRUCK. ak
  22. gimpyshotrods
    gimpyshotrods
    Not instant. It took me 8-years. I'm a slow learner.
  23. just remember dont buy super bell axles they are cast and they brake, mine did at 35m.p.h. buy SO-CAL axles they are forged
  24. ago
    ago
    from pgh. pa.
    Also Ch***is engineering and Lucky seven are forged as I'm' sure there are others. I believe Australia requires certified aftermarket axles.
    Ago
  25. ago
    ago
    from pgh. pa.
    Very true, But early in the last century the roads were really bad and the ch***is were really flexible. I remember driving my Dad's stock Model A in a gr*** undulating field slow and the whole ch***is would bend and twist with the landscape.
    Ago
    V8-m likes this.
