split wishbone to frame issue
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Mar 29, 2013.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    Still in the process of finishing my Av8 frame. I have the front end in, and split the stock model A wishbone. Installed the tie rod ends on the split bones.
    When I set the castor to 7* the tie rod would have to mount exactly on the lower radius of the frame rail. The way I see it is either drop the castor down to somewhere between 4* - 5* OR cut out a chunk of the lower frame rail and fab up a some sort of sleeve with the tapered bung welded to it. (picture C-notch but with a piece of round tubing)
    What would you do?
  2. Anderson
    Anderson
    Pie cut the wishbones.
  3. Russco
    Russco
    from Central IL
    Something doesnt seem right, they should be lower than that already I think. I had to pie cut mine and they were still mounted below the frame rail.
  4. n.z.rodder
    n.z.rodder
    Do exactly as you said, I wouldn't cut and weld the cast bones myself.
    Scotty
  5. n.z.rodder
    n.z.rodder
    It all depends on the ride height of the car. Some pics would be nice.
    Scotty
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    Wow, the thought of pie cutting the bones never crossed my mind.
  7. redroaddog
    redroaddog
    your dealing with castor. your degrees should be reading with the top of the king pin leaning back so if your lifting the wishbone up in the rear might not be right unless your spring mount in the center in high....pictures?:cool:
  8. Russco
    Russco
    from Central IL
    To get 7* of positive castor the car would have the front end higher than the rear to have the bones mounting at the frame rail. Are you sure you're not setting it up negative castor? yes post some pictures if you can.
  9. hillbilly4008
    hillbilly4008
    from Rome NY
    won't be able to get in the shop till probably sunday afternoon. I'll post pics then. front crossmember is stock, and I'm measuring from the face of the king pins. I can't measure from the top of the pins because I have the stock model A king pins in there.
  10. hillbilly4008
    hillbilly4008
    from Rome NY
    ****! you guys are right, I'm doing it backwards! haha, friggin brain farts.
  11. Russco
    Russco
    from Central IL
    This is how mine was after Pie cutting the bones and it still had to mount below the rail to achieve 7*, I cant see how yours is at the rail without being cut.
  12. hillbilly4008
    hillbilly4008
    from Rome NY
    Easy Russco, I'm doing it wrong!
  13. Russco
    Russco
    from Central IL
    That would explain it, you will more than likely have to pie cut it to get it where you need it but it does have to be at ride height to set it up. sometimes you can you put a socket on top of the king pin and check the angle from the socket?
  14. F&J
    F&J
    Who said 7 is what it needs? This is an old wives tale.
    It's bs
    Monkey see, monkey do.
    Take a look in Motors or Chiltons. Old fords were "4.5 to 9" in black and white. Some douche said to himself, "halfway is 6-3/4, so I will call it 7"...and all the sheeple magazine writers who don't know ****, have printed this f**** for decades.
    Caster depends on a least a dozen things, but all that is ignored.
  15. MATACONCEPTS
    MATACONCEPTS
    Watch for too much picutting the wishbon. From a side view, you dont want to triangulate the front suspension, that would "lock it in" so to speak, cause the axle to lunge forward when compressing the front. On an A, the lower the split wishbone frame connection the better articulation.
